Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Problem is with a Sears Progressive bag-less vacuum cleaner Mod. 116.35913401. The problem is while using the vacuum, my daughter experienced a shock and the machine went dead. Neither motor works and the lamp does not light. I checked for supply voltage at the PC board and it is present. I pushed and pulled the tab on the thermal cut off switch with no success then I put an ohm meter across the terminals and measured zero resistance. I checked for continuity between the PC board and the four board mounted switches that control the vacuum and it is good. I wiggle tested all the wire nuts and that did not help. The unit is dead as if there is a blown fuse. There wiring schematic mounted on the inside of the vacuum cleaner shows a thermal breaker, previously tested, and what appears to be a fuse but I cannot locate the fuse. The owner's manual says there is a motor protector switch mounted externally behind the hose on the right side of the vacuum when viewed from the rear but I cannot find it either. I am thinking the the circuit breaker and the motor protector switches do not exist. Need help.
  • 2,427 Answers
Is there a transformer on the Power circuit ?? check the transformer make sure each output puts out a voltage. Also check the earth system. If she got shock it means she got shock from the earth (ground system against the vacuum. Of she got shock from the on and off switch, check that as well..
Posted on Apr 02, 2011
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Whatn vacuum cleaner bag do you use?
You would use Kenmore 5055 vacuum bags .
Here is the link to the bags http://www.totalvac.com/kenmore.html
May 31, 2010 | Kenmore 25512/ 25513 Progressive Canister...
I WOULD LIKE TO KNOWHOW TO ACCESS THE FUSE IN THE
look around on the outside of the vacuum probably around where the cord is .look for a round black cap that has ridges around the outside of it.sometimes they say fuse on the cap.i'm not sure if there is one on the inside or not
Apr 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Progressive 3592
Well you could have a clog in the hose or the inlet down by the brush roll. other then that, if it s less then a year old, take it to Sears for repair, it would be under warranty.
Apr 16, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
54 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
