Question about Daewoo Washing Machines
I have bought a DWF-240P Daewoo TL Auto Washer 14KG 220V according to Invoice, the product delivered is DWF-240PS Daewoo TL Auto Washer 13 KG and was unfortunately not noticed till date (purchased about 3 months before). Can u please explain are the above two product different? Have I paid for 14 KG Washer and using 13 KG washer. Pls. reply
  • 209 Answers
SOURCE: whirlpool washer AWM5100
does your machine have numbers or letters on the control timer, whatever they are all you have to do is remember what numbers etc were on your old machine, generally speaking they are the same for all machines more or less world wide, for example 1 is prewash, 2 is 90 deg biol wash 5 is non fast coloureds etc, obviously this is just a guide as option buttons can variate this use as a rough guide and you should be ok
Posted on Sep 29, 2007
SOURCE: Testing appliance?
Call place you bought it asap, tell them you will call BBB. Then call manufacturer. Then call news media..
Posted on Apr 10, 2008
  • 409 Answers
SOURCE: New maytag washer
hi there,
since your washer is under warranty, have a tech take a look at it.
sounds like you may have a loose belt.
is there an error message on the display?
Posted on Sep 23, 2008
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
quatlew
  • 139 Answers
SOURCE: My new Whirlpool Cabrio stops repeatedly with the
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Posted on Mar 12, 2010
Testimonial: "Thank you I will check it out."
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Mar 15, 2014 | Washing Machines
Missing filter cap
Fixya does not sell parts and is unable to suggest sources.
Jul 28, 2017 | Daewoo Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
