Question about Splendide Washing Machines
I have a Splendide WD802 and the washer/timer is giving me problems. I beleive the part # is 116102529. Splendide wrote me back saying it is no longer available, but some retailers might still have it. Do you have an alternative. I saw that Equator have a similar machine and the washer/timer # is 116103032. would it work on WD802. can you help me on that. like you say there is a solution to all problems. Thank you
    New Friend:
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to use at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well or solder the connection. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Posted on Sep 24, 2017
2 Suggested Answers
SOURCE: Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Posted on Jul 03, 2010
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
How do you take the top off to get to the timer
first disconnect the 120 v power cord,and water hoses, remove the back panel about 6 screws, you should see the screws for the top.lift the top panel up to the front of the wash/dryer it should unlatch,to give you accsess.
Jul 21, 2014 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 model# wd802 drains byt will not spin nor turn
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to used at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Apr 04, 2012 | Splendide 2000S Front Load Washer / Dryer
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
Jun 29, 2010 | Splendide 2000S Front Load Washer / Dryer
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2100 Vented Washer-Dryer
A leak under the washer. model Splendide wd802
well there is a seal between the tub of the washer and the transmissition you cant see it utill you take it apart so just fill the tub with water and dont let the pumps or motors run if you are getting water from around the transmition that is your problem i have a maytag and that gasket cost just under 70 bucks so much cheaper than buying new washer
Mar 31, 2009 | Washing Machines
Maybe timer problem.
Here you find sellers where you can buy the replacement part, or more parts in the future, if the model is not in list, or if you have problem finding model number, then contact them.
Partselect.
Repairclinic.
Sep 28, 2008 | Splendide 2000S Vented Washer/Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
335 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
