I have no cold water entering the washing machine. So far I have verified screens on inlet hose and inlet washing machine are not plugged. Also verified cold water is flowing through hose. What's next?
  • Washing Mach... Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Apr 02, 2011
F20 error code
copied from the net..............
The "F20" fault code is indicating NO WATER IS BEING DETECTED ENTERING THE WASHER OR THE PRESSURE SWITCH IS NOT TRIPPING OR SENSING A TRIP.
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all the way and water enters.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit:
Verify drain pump operation.
Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
Verify there is not a siphon problem.
Press STOP twice to clear the display. The machine will drain for 3 minutes before unlocking the door.
Unplug washer or disconnect power.
Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU).
Check all hoses for possible leaks.
Plug in washer or reconnect power
Verify pressure switch operation.
I recommend calling a service technician to diagnose and repair your washer if water will entering the machine and not siphon out.
cheers
Aug 03, 2017 | Kenmore HE2 Plus Front Load Washer
My Kenmore Elite HE3 keeps flashing F H
F/H error is normally a malfunctioning flow meter. A good indicator is substantially higher water levels than normal, provided the flow switch has tripped its first set of contacts.
Condition
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Hope helps (remember to rate and comment this answer).
Jun 24, 2011 | Kenmore Washing Machines
I have a Whirlpool 27"
Failure
Code
Condition Check/Repair F/H No water detected entering machine or Pressure switch trip not detected.
Or
  • If there is no water in the unit:
  • If there is water in the unit:
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
May 07, 2011 | Whirlpool Washing Machines
Start load of wash, starts to spin, no water though, then flashes an F and H, eventually stops and machine starts to beep. I just did wash yesterday and haven't tampered with water levels, so can't quite...
FH means that the machine hasn't detected enough water entering the machine or possibly you have a problem with your pressure switch.
Potential Causes
If there is no water in the unit: • Make sure that both valves at the water source(s) are turned on all the way. • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves • Verify inlet valve operation
If there is water in the unit: • Verify Drain pump operation • Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch • Verify there is not a siphon problem • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU) • Check all hoses for possible leaks • Verify pressure switch operation • Verify flow meter operation • Verify CCU operation
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When I wash clothes it keeps beeping and has a flashing F H... what does this mean?
It means that the machine doesn't detect enough water entering or your pressure switch could be going bad.
Potential Causes
Stops running in middle of cycle and displays an f on the screen
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
  • 3. Verify inlet valve operation
Thank you !!
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer just hums when time for the water
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 14, 2009 | Washing Machines
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
Or
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
globul1a.gif If there is water in the unit:
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Or
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
