Question about Bosch WFL 2063 Front Load Washer
My bosch wfd 2473 has started to make a grinding noise when on spin cycle can anyone help
5 Suggested Answers
  • 49 Answers
SOURCE: Bosch washing machine not getting hot
one of 2 things, eather the element is faulty or the electronic control board wich puts power to the element is faulty.
more likely to be the element
Posted on Feb 21, 2008
  • 1462 Answers
SOURCE: WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Posted on Jul 23, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFD 2473 - wont spin. I've taken out the
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Posted on Dec 02, 2009
Testimonial: "Thanks - will try that now! "
  • 714 Answers
SOURCE: grinding noise upon start of spin cycle
mine does that and i believe it to be the clutch or transmission!
Posted on Jan 09, 2010
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
Bosch WFD 2473 - wont spin. I've taken out the filter and found a broken washer in it. Can't work out where the washer comes from? Doesn't seem to fit the filter. Having cleaned the filter, washing machine...
Dec 02, 2009 | Bosch WFL 2063 Front Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Feb 21, 2008 | Bosch WFL 2063 Front Load Washer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WFL 2063 Front Load Washer Logo
95 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
