Question about Thermador MBBS Microwave Oven
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
  • Thermador Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Apr 02, 2011
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Thermador Microwave Oven Model MBBS Serial No FD 8402000337 Runs but no longer heats food. Deep growling sound Light flashes from behind 4.25 x 5.5 " metal plate on right vertical side of oven...
Oh dear, I hope the magnetron still works. That plate you describe is called the Waveguide Cover. This cover must be kept clean otherwise the food particles will carbonize and cause exactly what you have described.
Contact the manufacturers web site for a supplier in your area or look on ebay, espares.co.uk depending on your location.
When it has been changed, I hope the magnetron/aerial is OK.
Dec 29, 2010 | Thermador MBBS Microwave Oven
My thermador microwave model mbbs makes a lot of noise and does not produce any heat output.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 26, 2010 | Thermador MBBS Microwave Oven
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Thermador Built-In Microwave MBBS/01 Diminished Power
Smell could indicate burnt rectifier or mag. ( Or Both) Even a partially shorting transformer that hasnt yet fully shorted out and blown your fuse. I do not know that unit, but if it would happen to have 2 mag systems you could lose 1 and it still heat but probably only at around half power. It has been a long while since I have had to work on a Thermadore. But last time I did I rememeber most of their parts distributors I used to work with had all closed. Do you still have a manuel for that unit from when you purchased it?? Try to find a contact phone number to see if you can call thermador. Ask them if they have anyone in your area doing service for them. While it may no longer be under warranty, a servicer who represents them will have parts, or acces to parts and service literature that other servicers will not.
Aug 16, 2017 | Thermador MBBS Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Thermador MBBS Microwave Oven Logo
312 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
