Question about Maytag Refrigerators
Fridge not keeping things cold freezer not working
  • 60 Answers
Check that there is not a frost build up in the freezer compartment if there is it narrows it down to the defrost timer defrost thermostat or the defrost heater
Posted on Aug 05, 2008
SOURCE:
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Fridge not working freezer works what should i do
see if you can hear the evaporator fan running in the freezer. if you can't you will need to replace it as this fan pushes the cold air from the freezer into the fridge to keep it cold.
Nov 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Jul 19, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Freezer works refrig part does not
You will probably have to completely defrost fridge, overnight. The air duct between the freezer and the fridge is probably frozen.
Jan 18, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
521 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
