Question about LG CRD 8522B Internal 52x CD-ROM Drive
I have 2002 Robotics computer with 2 speakers attached the wire at the back of CPU I tried to look the volume control but the PC speaker is not working
  • LG Master
  • 3,530 Answers
Welcome to Fixya
Try to plugin the speaker to a MP3 player for example Ipod. See if you are getting sount coming out to the speaker using the player. If you are getting sound coming out to the speaker then the problem is th port of the computer. If there's no sound then the problem is the speaker itself.
Let me know if you have further questions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 02, 2011
Hae i cannot hear sound from my pc after installing and replacing sp3 for sp 2 kindly assist me
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Aug 02, 2012 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Hi the sound in my speakers is reallllly low and i can't turn it up with the volume button like i used to, is there a wire missing or something ?? really annoying.. :S
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 15, 2011 | Koss HDM 11 Computer Speakers
I rebooted my computer,& now my speakers aren't givng out any sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Jun 23, 2011 | Altec Lansing VS2120 2-PC SPEAKER SYSTEM...
Sounds out of speakers and cpu
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 22, 2011 | Harman Kardon HK206 Computer Speakers
I connected a pair of Bose Companion 2 speakers to my PC but not getting any sound.
also
hope this helps
Apr 17, 2011 | Bose Companion 3 Computer Speakers
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
I have ceative SBS 245 speakers.2 das ago i did format my pc and install win7 .i have n sond.poblem find that no audio output device is install.please help us.
also
hope this helps
Mar 18, 2011 | Creative Technology SBS 245 2 Speakers
I was given the LS11 speakers and have connected them to my computer. However when I click on the volume icon in the tool bar to ajust the volume it does not work.
also
hope this helps
don
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
I plugged in power speakers (the cable green stereo plug which I plugged into the green inlet in the back of the CPU). I can see the volume level moving and I checked that it's not on volume mute) no...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 21, 2011 | Acer Aspire™ T180 PC Desktop
How do I install a volume control.
Ok, without actually seeing the back of it, I can't say where your connections go. But, I can tell you that there will be a positive and a negative for both L and R sides And 2 wires that go to your volume control on your amp.(1 for each side) you will be able to combine the 2 wires that go to your amp and it will still control both the right and left on your speaker.
Aug 10, 2009 | Audio Players & Recorders
LG CRD 8522B Internal 52x CD-ROM Drive Logo
26 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
