Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
I have an upright bissell pro heat self propelled. I have had it for years and it has always worked wonderfully. Last time I was using it water started going everywhere. The self propel part is only working intermittently and neither the floor or upholstery attachments will suction. If i put my hand underneath it feels like it is blowing air and water. The top part of the machine with the handle(where you push it) appears to be loose. If I press it together and push it down the self propel seems to start working. Not the suction though. I looked for screws to take it apart and tighten it. But I cannot find them and lost the original manual. Could the loose handle be causing the problems? Help. jessica sicahere@yahoo.com
    Problem Solver:
  • 8 Answers
If the top portion of the upright section is loose, there is a connector between the two parts that is also loose. No need to take it apart however beyond removing the black lower hose holder.
To remove the lower hose holder, just push in firmly on the tab that is the same color as the upright casing until you can pop the lower holder upward and off of the machine. Beneath the holder are four screw holes where you can tighten the upper and lower assemblies back together. This will reconnect the two connectors internally and take care of any power issue to the base.
Posted on Apr 17, 2011
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Hello.....my Bissell pro heat pro tech does not disperse the water....would you know why
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eytyet
May 21, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell carpet steamer not working
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and soap coming out wheel area
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
56 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
