Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Has anyone else had problems with a Emerson 1081 pool motor? We are our 2 one in two years/
  • 310 Answers
When motors fail, 99% of the time it was due to premature bearing failure, which was due to a faile shaft seal, which was due to either dry running, or chemical abuse, or a wearing wet end to the pump.
I install these motor at a rate of about 10 a week, and can say they operate great when taken care of. They do have a 1 year warranty if it was an actual failure, and should be taken back and replacced by the place you purchased it from if this is the situation. Emerson has a great warranty dept. and they support their products.
Posted on Apr 02, 2011
  • 2 more comments
  • groucho6 Apr 05, 2011
    ive recently been servicing several pools in a small community that recently had several pumps replace with emerson pumps befor I started working them. I do agree with you that 99% failure is due to bearing failure but I have had 3 emerson pumps go bad in this community that just died. any Idea what is going on here I have had 2 of them checked out in my local shop and all looks good from the outside but they do not power up and they do not have an answer.
  • adam hudson
    adam hudson Apr 07, 2011
    Is it possible that the motors your using are wired to the wrong voltage option?
    If the motor is set for 220volts, but you connect 120volt to it, it will run for a day, or a week, or a month at 1/2 speed and then fail all together.
    Check local on/off switches too to make sure that there is no bad switch cutting a 220volt circuit into 120volts or something strange like that.
  • Qualityps Apr 13, 2011
    Check the shaft bearings. See if they say China on them. I have a garage full of them I rebuild.
  • adam hudson
    adam hudson Apr 14, 2011
    I think if it was bearing failure, the above technician would be able to figure that out as the impeller would be stuck or hard to turn.
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 manual
What Emerson model, serial and or catalogue number do you have? 1081 is the basic and generic code indicating that it meets the standards for a pool motor, that's all.
Oct 16, 2013 | Emerson Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
I am looking for a starting switch for an Emerson motor it is a 2 speed motor # 1081 and 1795
look on ebay for... ask if you have a 2 speed switch ? fixya
Pool pump centrifugal start switch AO smith OR emerson
Aug 15, 2011 | Pool & Spa
I need to replace the bearings on a 1.5 HP Emerson 1081 Pool ump, Model number K62CXESE4792. Can I get the bearings from you?
YOU WILL NEED 1 OR TWO 6203 2RS AND MAYBE A 6204 2RS, THIS MOTOR CAN USE 2 SIZES OF BEARINGS. YOU CAN GET THEM FROM YOUR LOCAL AUTO PARTS STORE $$ .. OR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, IF YOU ARE LOCAL ? LONGWOOD FLORIDA. I'D GIVE THEM TO YA FOR FREE , NO CHARGE !
Jun 06, 2011 | Emerson Pool & Spa
I had a Smith 1HP pool pump with a square flange on my Haywwod sand filter. After 12 years it died. The pool shop sent me home with a Emerson 1hp., 1081 pool motor. It doesn't pull the water like the...
Sounds like there is an impeller problem. A 1hp emerson should be fine. Take it apart and recheck impeller and diffuser. I am assuming they gave you a new seal to replace with the motor.
Apr 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
How to replace the seal on a amerson 1081 pool pump
Thank you for posting your question here on Fixya.com.
What brand is your pump? Emerson and 1081 are motor related pieces of information. In general the process is the same for any brand...Disassemble the pump, lock the motor shaft at the end opposite the pump, spin off the impeller, replace both halves of the seal and assemble in reverse order. If you need more specific directions, please comment with the brand and model of your pump.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 03, 2010 | Emerson Pool & Spa
Describe your AO Smith 1.5hp Pool Pump Motor 2
According to our Emerson parts dealer, parts for that motor and the motor itself are obsolete. They could not provide a part number to search for or an equal part either. We can quote you a new BN34 if you wish to contact us through www.arrowpools.net.
Aug 20, 2009 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
1,198 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
