Question about Garden
Can't get soap to prime in Honda power washer...water will come out but, soap will not
  • 10,865 Answers
Hello ward.... that soap is too thick. add water to it to thin it down and then it will go through. joe
thanks for choosing fixya!
Posted on Apr 02, 2011
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
Do not have instructions on the mixer of water to soap. Where can I find?
20 parts water to 1 part cleaning solution is the common recommendation for power washers. Use only approved solutions or you can damage the pump. If the job is really grimy you can go as low as 7 to 1
Mar 30, 2011 | Honda 2500 PSI Gas Pressure Washer
The water is going out by the inlet soap fitting, and the soap compartment gets full of water
You will find that the non return valve as stuck inside your pump.If you follow the pipe back to the pump you will find a non return valve which is a ball and spring. Please remove this and replace if required.
this should then stop the water and soap returning back.
Jun 23, 2010 | Honda Pressure Washer PSI 3000
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
