My carrier puron is running but the air comming out of the vents is cool bit not cold. what could be the problem?
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Apr 02, 2011
My carrier condenser fan has stopped running.can i just pour water over the coil and use the condenser untile the repairman gets here on friday
Messy - why not just hook up a regular fan and hook it up to the power line that ordinarily powers the condenser fan.and have it do the blowing until the repair person comes out on Friday. The ideal fan is one of those old floor fans that used to blow air in a 360 direction.
Jul 02, 2015 | Carrier 3 Ton Infinity Puron A/c outside...
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
I replaced my whole heat pump system 3 years ago with a Carrier Puron unit. The installer called me this week and told me that I needed to replace the puron after the third year at a approx cost of...
Tell him you already had it done. lol. Unless you misunderstood what he told you no! You don't need to replace the Refrigerant weather it's Puron or Freon. It doesn't wear out. Ever. If your system develops a leak and you loose the Refrigerant it will have to be replaced but you will know you lost it because the system won't cool and heat like it's supposed to. I would report the installer to the better business bureau.
Aug 31, 2010 | Carrier Heating & Cooling
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
System pressure for puron read 280 and 135 for low side. System is not cooling at all. Suction line at air handler is not cold at all. System has had problems with leaks and customer has told me some...
the system must be leak checked, refrigerant recovered, evacuated, a drier installed, and recharged to the correct subcooling, (I assume this is a carrier since you reference "puron")
the low side pressure seems to be in line the high side pressure would be low depending on operating conditons, these systems must be charged using superheat and subcooling methods, pressures are just a "starting point"
Jul 06, 2009 | Heating & Cooling
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
AC will not cool. How much should a service charge cost?
If the upstairs is working and the down stairs is not,You only need to have one unit checked,Don't assume it just needs puron(If it does,You have a leak,which cost more to locate and repair than some other likely causes)This is not something you can do yourself and is illegal if you are not EPA certified.to get a fair price would depend on your geographic location and the best way would be to call around to some local heating and air companies and ask how much a service call is.(That only tells you the price for them to came and see what the problem is,They will not be able to quote a price until they know what must be done to make the repairs.
I hope this has answered all your questions.
Please take time to rate this fixya
May 16, 2009 | Carrier 38CKC036 Air Conditioner
Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Aug 01, 2008 | Carrier 38CKC036 Air Conditioner
Cools for a while ... keeps running but stops cooling.
If the refrigerant has been accurately charged and diagnosed, I would look for an air restriction. Check your filter first of all. It sounds like it may still be trying to freeze up. Make sure all the vents are at least a little open and the return grill is not blocked. In the Rocky mountain region we like to see around 44- 50 deg. at the vents. 65 would tell us that everything is not ok.
Jun 16, 2008 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
416 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
