Take a look at this link:
http://www.ehow.com/how_6155493_replace-delta-shower-valves.html
Your valve may vary somewhat but this should give you a good start.
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
SOURCE: Need to fix a leaking delta shower faucet and need
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
SOURCE: I have a single handle
you need to clean out the diverter before replaceing with new washers and seats.
