Question about Craftsman Garden
The chg oil light will not go off. We filled it with oil, so it should be fine now. How do we get the light off.
  • 608 Answers
It will go off two hours running time after initial indication.
Posted on Apr 11, 2011
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
LTX1050VT/chg oil displayed red oil flashing when key is on
Could be that the light will go out 2 hours after an oil change.
Check out 'My Tractor Forum'.
Jul 09, 2011 | Sport & Outdoor - Others
How reset oil light 2009 pontiac wave g3
Turn on the ignition with engine off.
Fully press and release the accelerator pedal 3 times within 5 seconds
Turn off the ignition
It is in sections 3 and 5 of the owners manual if you ever need to refresh this next time.
Nov 08, 2010 | 2009 Pontiac G3
How do I reset the change oil soon message in my 1998 Chevy Lumina after changing the oil?
This is done by turning the key on engine off and fully pressing the gas pedal to the floor sloowly three times within 5 seconds, the light will blink and go off then turn the key off for 3 sec and start engine, light should be off if not repeat steps. hope this helps.
Oct 27, 2010 | 1999 Chevrolet Lumina
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CHG OIL prompt on Saturn odometer - oil has just been changed
check owners manuel there is a procedure to reset it. if you don't have manuel try turning the ignition on and pressing the gas pedal down twice then turn off key and turn it back on again
Oct 15, 2009 | 2003 Saturn ION
92 Camry, have to start several times before engine turns on, onl
weak fuel pump, clogged injectors, air or coolant temp sensors out of specs. Timing belt was put on wrong. Timing is off. Map sensor out of specs. You do have a light on. Fixing why the light is on may fix your problem.
Aug 06, 2009 | 1993 Toyota Camry V6
CHG Light Showing, in our 81 Corolla CS what dose this mean?
Your chg light is your charging system. It could be your alternator, battery, cables, wires etc. Generally pretty easy to diagnose with a multimeter. To check the alternator the old fashion way, you can start the car and disconnect the battery while it is running. If the engine stops then the alternator definately has a problem. This is not recommended as it is much safer to use a multimeter.
Apr 30, 2009 | 1983 Toyota Corolla Deluxe
1989 chevy 1500 p/u has no drive or overdrive
two trucks with the same problem.does not sound good. how many miles on thies trucks? when was the last time the trans was serviced? if its been awhile it might be time for a trans chg. or you can try a oil and filter chg. you are only out about 30.00 bucks or so for this. but first i would pull the dip stick and smell the oil if it smells burnt that might not help. if its well over 50000 miles sense its been serviced 86 that trans. for a rebuild or a used one from your local bone yard. but if you do not know what to look for i recommend a rebuild. good luck.
Jan 02, 2009 | 1999 Chevrolet Silverado 1500
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
