Question about Brother Office Equipment & Supplies
Brother MFC 720N printer is not pooling pages out of the tray. apparently the part that is supposed to lift pages up is not working properly The cogs are spinning and the tray is not broken... Thanks Nadav
SOURCE: Brother MFC 8460N All in one
Remove your tray.
Push it from the back and make it sure it's tight against the paper.
Move the blue button to the "unlocked" position.
Should be good to go!
Posted on Jun 18, 2008
mitpatterson
  • 74 Answers
SOURCE: replacement paper tray for Brother MFC 5440 cn?
If you go to brothers website you should be able to order a new one from them for about $10 USD plus S+H or so
Posted on Oct 19, 2008
  • 17 Answers
SOURCE: How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
http://www.sharperminds.net/downloads/instructions_for_changing_a_fuser_gear_on_a_brother_printer.pdf
Hope you find this helpful.
Ed
Posted on Feb 25, 2010
lserni
  • 466 Answers
SOURCE: I have a Brother MFC-9440CN Laser Printer -reinstall tray message
Rule out the software solution: is the document being printed of the same size of the paper in the tray? If not, you'll get a spurious tray error every time you print and then e.g. someone else prints another document with a different format. See Control Panel > Printers > Properties > Tray for this.
Then the hardware/firmware options: there could be either some dust or grit in the tray sensor, so that it doesn't "feel" the tray until it gets nudged, or the chassis (or maybe the tray) got slightly deformed and no longer properly activates the sensor. This is a white dot inside the tray slot on the bottom upper left; try blowing some compressed air on it. A McGyver solution to a warped chassis can be to apply adhesive tape on the facing part, so that it is thickened and improves contact with the sensor. Not really recommended of course, and the tape is bound to come off or wear out, and maybe jam the sensor even worse, sooner or later.
A replacement tray kit may cost anywhere from US$ 150 to US$ 300 depending on source.
Another possibility is that the tray counter has reached end-of-life. Press # 72 and check whether the page count is 288,888; in this case there's a firmware problem and I am not sure of the solution (it's known as the "Brother 288,888 page count problem"). This is unlikely - I don't know that firmware ever got in the 9440. But checking costs little.
I quote the reset procedure for end-of-life reset -- use wisely.
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
Press 3 and 9 at the same time in the ready status on power on.
The “Reset Menu” will appear on the LCD. Choose applicable periodical replacement part with the arrows. Accept with OK. Press 1 to reset the counter, or 2 to quit without saving. STOP to exit menu.
WARNING: using the machine with an end-of-life'd component may damage the machine, not only that component.
Hope some of this helps. Let me know how it goes...
Posted on Mar 24, 2010
tbreeze47
  • 3083 Answers
SOURCE: Our Brother MFC-8860DN will only feed paper from
Printers have rollers that grab and feed the paper. They can get dirty over a period of time, or lose some of their "stickiness". Sometimes they're easily accessible, sometimes not, depending on the printer. They can be cleaned with alcohol and q-tip or cloth. The weight of the paper is probably causing just enough resistance to make the printer think there's a jam, but there could also be a problem with the mechanics of the sensor assembly, or a fragment of paper jammed up somewhere. Sometimes you can get it working without taking the machine apart, and sometimes you can't. Make sure you don't void any warranties, of course, but with some investigation, you might get lucky. You've probably done most of what I suggested, but you might take one more look. Good luck!
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
How to print on legal paper brother mfc 8680dn
Hi G gur,
Go To Below official Brother Printer Page For Your problem,
How do load legal size paper in the paper tray Brother Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Nov 15, 2013 | Brother Mfc-8680dn All-in-one Laser...
Mfc-8460
Whats the problem? Lots of printer trays are like that. The printer, when powered on, will lift that. Look on the side of the tray there is a mechanism that makes contact with a gear inside the printer.
May 02, 2013 | Office Equipment & Supplies
Two side print mfc-7340
i am unable to change the language from Turkish to English
Nov 29, 2012 | Brother MFC-7340 All-In-One Laser Printer
Brother printer keeps reading "no paper".....it has paper in it.
try paper in mp tray if that works your bottom tray may not be lifting
May 18, 2010 | Brother MFC-8860DN Printer
Brother MFC 8860: Display reads
I have exactly the same problem with my Brother 1250 mono laser printer.
Any solution yet?
May 11, 2010 | Brother MFC-8860DN Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC3360C paper drawer will not open
remove the paper tray
remove the jam clear cover in the back.
Lift the Pull In Roller
Holder Assembly with a
credit card.
be careful not to lift too much
While lifting the Holder
Assembly, pull the tray
free from the machine
lubricate the right side with a little bit grease where the vshape is located on the tray
Apr 16, 2009 | Brother Multi-Function Center MFC-3360c...
Manual feed
Apparently this arises out of a software progarm you msut be suing. Sorry but I'm so technologically illerate that I am unsure what the Brother Helpdesk was really meanning. Anyway after lots of dieffernt attempts at various things, I turned it off for 30 seconds and presto shes fixed. Ridiculous I know but it worked for me
Jun 23, 2008 | Brother MFC 7420 All-In-One Laser Printer
Mfc-420cn paper tray
Your paper tray is complete. The lifting section doesn't look as if it fits properly, but it's only there to keep finished prints from getting pulled back in with plain paper.
Mar 03, 2008 | Brother MFC 420CN All-In-One InkJet...
96 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
