Question about Vacuums
My Rowenta DX8700 iron leaks. Is this something I can repair? I have fixed the cord several times.
3 Suggested Answers
  • 16 Answers
SOURCE: How do I fix my
Some gasket of flat iron wear out in time. To remedy this problem you must first detect where the leak was coming from. Usually it comes from the area where the water meets the vaporizing chamber. When you found the leaking area you remove the water dry it thoroughly and apply a high temperature gasket maker at the leak and wait it to cure naturally. Usually one day is enough to get the flat iron to work again.
Posted on Jan 03, 2011
  • 273 Answers
SOURCE: I need to replace the
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Posted on Jul 11, 2011
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
Jul 11, 2011 | Vacuums
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
How do I fix my Rowenta Iron? It leaks from the base. It has never been dropped.
Jan 03, 2011 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
How do i clean my rowenta steam iron
run some c.l.r clear through it
Sep 25, 2010 | Rowenta Vacuums
I was getting ready to iron a pair of pants that were polyesterrayon and 4% spandex. I thought I had my Rowenta iron turned down low enough but when I placed the iron on the pants they melted. Well...
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Jul 04, 2010 | Vacuums
I have a Euro Pro Compact Performer model # EP 171 which I love. It is the best iron I have found for my quilting class. When I went to use it, I found my cats had chewed the cord to the point that it is...
HI. All appliances has warranty on it. Default would be 1 year warranty. If your device is within the one year warranty. you can have it repaired by your manufacturer withut a charge. If device is alraedy out of warranty. you can still have it repaired but you will cover for the damaged part that need to be replaced or repaired in your device. Check the store where you purchased the unit. Maybe they can do something about it.
Jul 01, 2010 | Euro-Pro Vacuums
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
