Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Our oven made a soft bang and F1 appeared. The Low setting on broil still worked as did the top elements. After unplugging it and replugging it in the F1 came back again this time with an annoying beep, so we unplugged it again. We would like to use the top elements as we still need to cook but the annoying beeping prevents that. Also with your answer please give an ball park estimate as to the repair bill (I live in Canada) or an honest answer to toss it out and buy new, which is not my first choice. I have found that the repairs on these appliances to be so expensive especially as the stove is over 7 years old but nothing is made to easily and economically repaired these days...this is a shame as most of the range is still in excellent working condition. Thanks for you help ...I appreciate this website!!
  • Kenmore Master
  • 3,053 Answers
Hello, lyons
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
My samsung flat top electric oven or broiler want work and it's reading error code E-08
E08 is a oven heating error which basically means there is either a problem with the heater or the oven sensor. In this case i would check the oven sensor with an ohms meter. should read around 1080 ohms at room temp. Also try unplugging the unit for 30 seconds.
Apr 14, 2015 | Samsung Ovens
RF367LXSS 4 when temperature is set, the oven elements are not getting heated? Both broil and heating elements are not working
Did you ever hear a bang or a crack sound from the oven? Shine a light and see if any of the elements appear to be bulging or black. It is possible one or both the elements burned or shorted out and need to be replaced.
Aug 25, 2014 | Ovens
Broil does not work
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Aug 05, 2014 | Kenmore Ovens
Broiler wont work on maytag oven
the broil element
Apr 27, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler turns to pre heatworks oven doesnt heat when temp
the broil element
Apr 15, 2014 | Kenmore Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
37 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
