Question about Motorola MR350R Two Way Radio
My motorola MR350R will not communicate with the other radios. they are all on the same settings but it won't work. and when it is on a main channel (say 4) and a sub channel of 0, all you hear is static like it is broadcasting whatever might come up on the channel. How do i get rid or this so it will communicate with the others again?
Neto
  • 123 Answers
SOURCE: motorola t5000
If you have already checked both radios have the same code and channel both radios must reicive and transmit between each other check if you have any QT in any display this is a third condition to reicive.
Posted on Jun 07, 2007
eradiostore
  • 1654 Answers
SOURCE: I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Posted on Jul 30, 2008
eradiostore
  • 1654 Answers
SOURCE: Problem with Motorola t8500
Check your Qt filter setting. It works best in the "off" position.
Posted on Jan 19, 2009
alexis_garci
  • 4 Answers
SOURCE: T8500 no recieve transmit vibrates when PPP is pressed
Try using a new set of Alkanie Batteries, if it Work your battery Pack KEBT-071 is broken, got charge memory problem you have to reset the charge cycle or buy a new one.
And remeber Always tun off radios before charging.
Posted on Jun 12, 2009
alexis_garci
  • 4 Answers
SOURCE: Motorola T8500 Communication Problem
Agree with eradiostore, check your batteries and battery contacts. Remenber to turn off the radios before charging.
How to fix my walkie talkie
U replace a broken unit. Not cost effective to fix.
Mar 03, 2016 | Motorola MR350R Two Way Radio
Won't Receive, is there a setting I acidently activated?
You want to make sure you radios are on the same channel (big number on the display) and your Interference eliminator code (small number on the display) are the same. Also, make sure when testing that your QT is turned off.
May 04, 2015 | Motorola MR350R Two Way Radio
What are the more commom problems mr350r
Contact Motorola Solutions Support. They can tell you
portal motorolasolutions com
Mark
Motorola Mobility Support
Jun 19, 2014 | Motorola MR350R Two-Way Radios
Not working
This radio may need to be replaced, but before doing so try the following:
Trade batteries with a known good unit and see if the problem moves to the other radio.
Check your buttons to see if one is partially depressed or stuck.
Check to see you do not have the radio set to VOX mode.
Shut off all special features and go back to a basic setting with the frequency and code matching your other units. If it does not communicate then, you have a radio which needs replaced.
Jan 22, 2014 | Motorola MR350R Two Way Radio
Broken display screen for mr350r
Parts for this model were never made available from Motorola. You could try looking for a replacement, or parts radio on ebay.
Best regards.
Feb 07, 2013 | Motorola Talkabout Mr350r 2 Way Radio
How to hack into a motorola mr350r radio and change the frequencies
Hi, Jeremy,
Not Advisable, apart from being illegal, you can cause irripairable damage to your radio.
These radios were designed to operate on specific frequencies only.
My advice....Don't Do It!!!
Hope that answers your query.
Cheers,
Peter
Aug 04, 2012 | Motorola MR350R Two Way Radio
Cant comunicate i set it up everything off and put sub channela on zero and still nothing happens heeeeeelpppp
Just discovered on my radios that one freq is slightly off from the other. I was able to communicate using ch22 on one radio and ch7 on the other.
May 12, 2011 | Motorola MR350R Two Way Radio
Will the motorola mr350r work with the motorola cs1110
  • The mr350 is a standard GMRS/FRS talk around radio and the cls1110 is a business band radio but bot operate in UHF. So if the cls1110 is programed to one of the frequencies I will list then the two will communicate. Otherwise they will not.
Here are the frequencies listed in order of channels on your radio. 1-22.
Apr 30, 2011 | Motorola MR350R Two Way Radio
It doesn't receive any message but it does play the call alarm and sends the speaker's voice.
Check your programming. All the radios must match on Frequency, Code and Qt filter if any. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
For simple operation, turn off all the special features. Start by turning off the Code (set to zero for off), Qt filter, and call tones. You can add them back in once you establish communications.
Best regards.
Oct 25, 2010 | Motorola MR350R Two Way Radio
Motorola MR350R  Two Way Radio Logo
115 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
