Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
New hp8500a premium printer. want to hook up through airport extreme router and be able to use with microsoft xp and microsoft 7 on laptops wirelessly
    President:
  • 1,623 Answers
Just setup the printer by connecting it to your wireless network then once its connected to the wireless network, go into control panel and select add a printer on your xp and windows 7 laptops and choose network or wireless printer and select it when it finds it. then when you print something from either printer it will use the printer
if you found this info useful please vote for me
Posted on Apr 02, 2011
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
I have a macbook and a pc with a cable modem and an airport extreme. I want to hook them both up so I can use the internet at the same time on the pc and the macbook. How do I do this or hook it up?
Not sure what you have tried yet, so I'll suggest the first thing to try ...
The cable modem will have an ethernet jack on it for "LAN" - you will need an ethernet cable ... plug the cable into this jack .. and the other end of the cable into the airport extreme .. and then power up the airport extreme .. if the airport extreme is new, it will set itself up automatically .. if not new, it might still set itself up automatically - look for a green light on the extreme ... if you have a green light you should be in good shape
Of course your computers have to be in range, say within about 100 feet of the extreme to pick up its wireless signal.
In the MacBook, make sure Airport is turned on - in System Preferences under Network.
Your MacBook should figure things out all by itself and you should be able to connect to the Internet.
On the PC, you'll need a wireless card if you don't already have one ...
You should be able to use the internet simultaneously and each computer should be able to share files if you want to try that (file sharing is turned off by default on the Mac, not sure about the PC)
For AA speaker tapes and PA system help with feedback and echo, see my blog at rexark.com
Dec 19, 2009 | Apple AirPort Extreme Router
Printer not working from new router
First, I would suspect your PC has the printer installed using the IP address of the printer. I would uninstall the printer, then go to "add printer" then "add network printer" and see if this works. If not: HP has a neat setup available for their printers. Go to their website and look for network printer setup. This will install on your computer, and go through your network and find your printer.
Nov 30, 2017 | Apple AirPort Extreme Router
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Computer does not see the printer
I was told by HP that I could not use USB over a network. I Called Apple support and was hooked up through my Airport Extreme using USB. You want a better solution invest in a Mac. They have the know how and what they are doing. It's like comparing a Model T to a Cadillac when you tout PC's.
Mar 21, 2009 | HP Office Equipment & Supplies
MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Help to install R280 with a router for windows xp
I can help you with this. I sell belkin and provide help let me know if I can help
Jan 11, 2008 | Computers & Internet
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
