Question about Acer BATBL50L6 Laptop Battery
I just replaced my laptop battery - BATBL50L6. My charge light flashes orange. Win7 says plugged in, not charging. shows 0%. I tried reinstalling the ACPI battery monitor in DM.
    Sergeant:
    Champion:
  • 345 Answers
Try putting the old battery back in and see if you get the same problem. Also check where the chargers plug goes into the laptop. If it fits loosely your charger port needs replacing.
Posted on Apr 02, 2011
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
http://tim.id.au/laptops/toshiba/satellite%20and%20pro%20220%20440%20460%20470%20480.pdf
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Acer BATBL50L6 Laptop Battery Logo
190 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
