Question about Hamilton Beach BrewStation 47214 Coffee Maker
Why am i getting a pour water error message on my coffee maker
    New Friend:
Found the answer in an Amazon review. Place a small bamboo stick in the water sensor located in the resevoir. The ERR code disappears and you can brew as normal. If you leave the stick in, measure water carefully as there is no auto shutoff.
Posted on Feb 19, 2015
  • Deanna McAllister Sep 26, 2016
    Coffee maker will not brew coffee. It flashes "pour water" and shuts off. It is not leaking any water. Help please
popsgifts
  • 160 Answers
SOURCE: I have a FT series Mr Coffee (Black and Silver)
Could be as simple as a hose that popped loose, or as serious as a cracked tank...the only way to know for sure is to pull the bottom plate and have a look.
Most retailers have a generous return policy, and you never really know what you can't have until you ask...but if this is not an option, a 30 minute project could save you the replacement cost.
Remove the base plate screws* and lift easy to reveal the heater element and hoses to the water tank.
*Torx screws (a star pattern) require a special driver that can be found cheap at any auto parts store.
Check the hoses one at a time for leaks (cracks, dry spots, tight fit, etc) and look at the bottom of the tank for a split or crack.
Place the bottom back on (no screws yet) and add a little water...If it stays, then you got it.
If it leaks, lift the machine to eye level, drop the bottom out of the way, and add a little more water so you can watch for the source of the leak.
A broken tank means a new machine...but a bad hose can be replaced.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
t955i
  • 30 Answers
SOURCE: Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Posted on Apr 26, 2009
  • 18 Answers
SOURCE: coffee maker leaking water out of every hole in the bottom
hi ninerh! this may be an easy fix for you, or may require some replacement parts. if you need a new length of hose, try a hardware store or try a local medical supply as a source for new tubing (must be right size, food-safe & able to withstand heat) or espressoparts.com/cafeparts.com. if you can turn a screwdriver, remove ten screws in base plate (machine must be upside down & make sure it's cooled down/unplugged first!) gently lift base away--bottom most hose leading from where resevoir sits to pump should be held in place by a cheap wire clip; this may have come loose over time w/ vibration of pump, or it may be damaged. *be careful removing bottom of machine b/c wires lead from it to inside of machine; don't be scared, just be careful! good luck!
Posted on Jan 11, 2009
  • 56 Answers
SOURCE: The coffee maker doesn't work
Does it make steam or can you hear the water boiling? Try and pour 4 cups of vinegar or lime away in it if it is clogged or plugged up from lme or mineral deposits, if it not getting hot( you can tell very easily by seeing if the plate the pot sits on is getting hot) then the thermocouple or heating element is shot.
Posted on Jan 26, 2009
SOURCE: On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Posted on Dec 20, 2009
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
Dec 31, 2013 | Bunn A10 Coffee Maker
I have B60... I have descaled it twice wit vinegar... water is coming out although not as fast as it should. Descaling light still on... what should I do?
Vinegar is really not good for cleaning coffee machines.
You should rather use acetic acid.
1) put 4 cups of water into the coffee makers tank.
2) pour 4 cups of acetic acid also in the coffee makers tank.
WARNING !!! ALWAYS pour ACID into WATER and NOT the opposite !!!
If you pour water into acid, it can explode and cause severe damages !!!
3) Let it run through the coffee maker.
4) pour hereafter water in the tank and let it run through 2 times.
If this does not help to decalc your coffee maker, it is time for a new coffee machine.
Good luck
Aug 22, 2011 | Keurig Platinum B70 Coffee Maker
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
On the screen is the error message - ventilate- wjat do I do?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
May 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Syncrony digital gaggia coffee maker leakage+ventilate message
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Unit does not brew all the water from the resevoir
This usually means that you need to get a new coffee maker.
Nov 19, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Jun 02, 2009 | Bunn GR10 Coffee Maker
Hamilton Beach BrewStation 47214 Coffee Maker Logo
6,736 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
