Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
We just replaced our old minimax 100 with a new one. Plugged it in, turned on the heater and it ignited perfectly. There is water flow and it has heated up but smoke is coming out from under the coils. Is this just burnoff not to be concerned with?
    Problem Solver:
  • 20 Answers
I've never had smoke, but I have experienced a " smell " that burns off the first few times direct from the factory. I would call technical support to share your experience. 1-800-831-7133 or 1-888-755-7946.
Posted on Apr 04, 2011
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Minimax 100 runs for about 5-8 minutes and then shut off. Won't come back on for about a hour
Check your water flow. If you have an external by-pass valve it need's to be 80-90% off so water will flow through heater. Also you will need to check the internal by-pass. You can find it inside the water manifold and if the external one has been left open it can cause the internal one to go bad. With out these the water goes past the heater and the water inside the heater overheats and shuts the heater down. With nothing to divert the water flow through the heater to bring fresh cool water in it will just sit till it cools and go through the cycle again.
Sep 07, 2010 | Pentair MiniMax 100 Aboveground 100,000...
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Jul 04, 2010 | Pentair Minimax 100 Pool Heater
High pressure, and heater noise
I am not sure if you have solved this issue, or not, but if the PSI on the gauge is high then the problem may not be the heater. When you have the system turned on, and the PSI is reading higher than normal, just the flow of water coming out your return lines. If the flow is normal, like when you clean your filter, then see if you have a way to re-route the water so it bypasses the heater. If the PSI on gauge drops, then the issue is in the heater.
If the flow of water is slower than normal, with the PSI reading high, then you have a blockage somewhere in the system. It could be something simple like removing debris from skimmer and pump backets, to time to backwash, or clean, the filter.
If the flow of water is really hard and fast, with the PSI high as well, then you have too much water going through the system and need to slow it down.
Jun 27, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Hi, I have a minimax 400 heater it will only bring the spa up to 85 degrees, the power light and temp light are on.
generally if you can only reach a temp of 85 or so you may have an oversized pump and the water is flowing too quickly through the heater. it may be necessary to install a manual bypass on the heater plumbing to divert the water enough to slow the flow through the heater down
Jun 11, 2009 | Pentair MINIMAX NT TSI IGNITER
Pool heater cycles off and on
insert on hot water and see if open or close than on cold water and must reverse from hot. if nothing happen replace
May 29, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
70 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
