Question about LG GD510 Cell Phone
My screen is like moved to the left side...it looks ok but when i try press something i middle it looks like i prest the left side,so if i try on the right side no reactions, how i can reset settings for screen or something?
Hey David...There is one sol 4 it...
step1: go to touch screen setting from ur manu...
step2: select 1st option--touchpad celebration..
step3: hit the rad and blue dot point with ur mostly used finger...
it will set ur sceen best for u...
_____Kapil Gajjar
Posted on Apr 03, 2011
How to reset an ir2520 leser printer?
On the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
May 03, 2014 | Canon Office Equipment & Supplies
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
4gb pmp350-4 mp3 player touch screen. Screen is back only can see a shadow images of icons try to reset screen is still very dark. can this be fix?
From the main menu of you mp3 player touch the lower right corner of the screen, then touch the lower left side of the screen, then press the lower middle section of the screen. Then press the lower left side of the screen again and then the lower middle screen. Then press the lower left side of the screen until the screen brightens. From there you should see your screen to further assist yourself...Your welcome(:
Dec 27, 2010 | Polaroid Juke Jam PDP602 MP3 Player
I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    How to change the date and time
    According to manual, press the Menu button. Then press the right side of the big button with OK in the middle. This will highlight the setup menu (the wrench and hammer icon). Press the down button (lower part of big round button) to highlight date and time. Press up, down, right or left of big button to move cursor and change values. The press OK. Press Menu again to exit.
    May 09, 2010 | Mustek DV526L Camcorder
    I'm having trouble deleting pictures any advice would be helpfull.
    normal procedure for deleting images using a dscs700 cam.
    1. press playback button (button you use for viewing images, located just above the lcd screen,left side w/arrow icon pointing to the left)
    2.salect the image by pressing the left or right control button
    3.once image to be deleted is selected, press the delete button (2 black squares w/a slash and garbage can icon,below the control buttons on the left side).
    4.select delete option by pressing the up control button.
    5.press middle of the control button to confirm.
    ...or if you would like to just remove everything on the memory stick including protected images you can just format the ms by:
    1.press menu to diplay menu settings.
    2.press right control button to go to setup (looks like a toolbox or suitcase icon) and press the right control button again.
    3.press the down control button to go to Memory Stick Tool and press right again to confirm selection.
    4.press right control button to select format.
    5.press up control to select ok and press middle control button. message will appear telling you that "all data in ms will be erased.ready?"
    6'press up control to select ok and confirm by pressing middle control button.format completed.
    hope this info helps. thanks:)
    Apr 13, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
    How to set a timex i-control watch
    switch to time mode, and hold the middle buton on the left side until the watch shows SET TIME. press the next track button to set the hour (blinking on the screen) by pressing the + and - buttons to change the value. press the next track button to move to minutes, then seconds, then month, then day, and then year all being changed by the + or - buttons. then press the left middle button to exit. Congratulations, you just set your watch :D
    Sep 23, 2009 | Timex i-Control 29571 Wrist Watch
    Motarola i290 has screen LCD Contrast Calibration: SOLOMON size 130x130 CP Cal = 0 ( Room Temp ) Manual: < or > then the word skip in the bottom right corner Not responding to anyhing
    1. First you press your messages button where they are located
    2. Now scroll down to where it says Inbox and make sure it is highlighted
    3. Next press the button that looks like two pieces of papers one on top of the other...it is next to the OK button in the middle but on the left side.
    4. Next you will see something that says Setup...press OK
    5. Scroll down to where it says Cleanup press OK and you will see Inbox and Sent Items on there. Choose your Inbox ( you can also do the same for sent items)
    6. Now just choose how often or how many messages you want cleaned up...then press the OK button.
    7. It will automatically ask you if you want to do this now...choose yes
    Jul 15, 2009 | Motorola Mobility I335 Cellular Phone
    Cursor stuck in the middle of screen!!!!!
    this happened to me. try pressing the Fn key (mine is in blue, next to the left control key on the bottom of the keyboard) and hold it while you press the F7 key and release. try moving your mouse. Those two buttons together turn the touchpad device on and off.
    Mar 31, 2009 | Acer Aspire 3100-1405 Notebook
    Speaker phone
    Hi.
    When u place a call, look at the screen ( bottom middle) and when the little phone icon shows up, press your ok/i button(the silver button in the middle) to activate it. Alternatively, if someone calls u, when u pick the call up, on left side bottom of screen it says option, select speakerphone.
    Feb 04, 2008 | Samsung SGH-D900 Cellular Phone
    LG GD510 Cell Phone Logo
    150 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
