Question about Onkyo TX-SR606 Receiver
No sound from Zone 2 of my Onkyo TX-SR606. Zone 2 speakers are ACT (activated).
mrwtech
  • 59 Answers
SOURCE: Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Posted on Dec 30, 2007
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
  • 17 Answers
SOURCE: I have an onkyo tx-sr606
hi there. try to check if your surround speakers are on the surround terminal. do not put them on the surround back terminal because this is only allotted for the 7.1 speakers. hope this helps.. ^_^
Posted on Nov 28, 2008
  • 17 Answers
SOURCE: receiver - onkyo tx-sr606 problem
if the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Posted on Dec 09, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Zone 2 stopped working. When pressing the volume button for Zone 2 , message appears : "Pwrd Z2 not Act." Do you know how to correct?
Go into Hardware Setup, find the setting for Powered Zone 2 and ACTIVATE IT. You will lose the Surround Back speaker function when you do this. Zone 2 and Surr Back are mutually exclusive.
Jul 14, 2010 | Onkyo TX-SR703 Receiver
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
Zone 2 audio output is for analog only? The only reason I bought this receiver was to be able to play my ipod on our outdoor speakers.
David is wrong. My Onkyo is the same way. The receiver will only provide a signal to zone 2 speaker outputs from analog sources. I assume this was because of concerns with digital rights management, which caused some odd decisions for a while by hardware manufacturers. Newer receivers should not have this problem.
Apr 26, 2010 | Onkyo TX-SR606 Receiver
No sound with the tx-sr606
This is a problem of DSP. If enter service mode,
You will see a picture like this. You can do nothing
Except selling this amp cheaply. This DSP ??????
Causes NO SOUND in all channels. Besides, never
Buy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848Series amps. You will suffer the consequences!!!!
dsp problem-cul4vjmzkuvncverhuthjcbk-4-0.jpgdsp-1-uogyjvcdpkwkvogd1g1ztygl-3-2.jpgdsp1-uogyjvcdpkwkvogd1g1ztygl-3-3.jpg
Feb 13, 2018 | Onkyo TX-SR606 Receiver
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Jan 19, 2009 | Onkyo TX-SR606 Receiver
Onkyo SR606 - Loud Poping
It could be a number of things,
1. an electrical short in the house. Try plugging it into another circuit with an extension cord.
2. A bad RCA cable that is input from one of your sources.
3. its probably a bad unit if you have Zone one and two playing at the same time the same source, but it only happens on zone 1.
4. a bad speaker can make a poping like sound, does it happen on all speakers? unplug all but one and one at a time try to determine if the problem sticks, if not, then one of the speakers is out of phase or blown.
5. Playing music froma computer source will sometimes make a pop if your computer is slow or bogged down with checking emails..etc. mine sometimes studders PPPPPPPrioRRRRRity CCCCCLLLLLLLLEEEEERRRRANCCCEE AAAAAAALLLLPPPPPHAAAA OOOOOOONE.
it also pops real loud when booting or shutting down.
Personal note ........windows is such a hassle for Media systems.
I hope something here helps!
Charles
Dec 31, 2008 | Onkyo TX-SR606 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Onkyo TX-SR606 Receiver Logo
443 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
