Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Steam doesn't come out - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Apr 02, 2011
Everything is working as it should, but it doesn't steam
Minerals in the water may have solidified and clogged it. The vinegar is an acid which can help to dissolve and flush and rinse out the minerals.
Sep 01, 2017 | Black & Decker SV1000-4 SteamBuster Vacuum
Shark steam mop S3501A doesn't make steam
My shark wouldn't steam with the head on so I cleaned the holes with a paper clip and then poured CLR through it and it is working now.
Aug 02, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover steam carpet cleaner - turbine needed for F7458-900
Once you get the turbine out, open it up by unlatching the three latches and unscrewing two screws. Pull the gears out and WD40 everything. Let it sit for a bit and start turning the solver gear at the back with a pair of pliers. Once it is loose, put all the gears back together and return everything to it's place. FIXED! without buying a new turbine....
May 30, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam is coming out. the orange light is on.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Jun 14, 2011 | Vacuums
Steam buggy water reservoir cap has apparently been cross threaded, and cannot be removed by twisting or other "encouragement." If I cut it off, where can I get a replacement? Can the machine be used as...
You need to completely annihilate the plastic cap by cutting it off and destroying the remaining plastic to expose the stainless steel insert/plug. You can use either a pipe wrench or 11mm wrench to turn the insert counter-clockwise to unscrew. You will need to use some force to get the plug out since it's basically glued shut by lime deposits in your tap water.
Do not move the slotted cap or else this will need to be adjusted so that all your water doesn't squirt out before turning to steam.
Next time only use distilled water. Store with the cap off. Grease the inner and outer threads after every use and wipe it off completely before use so it doesn't mix with the steam and turn to vapor.
Sep 23, 2010 | Tristar SB Steam Buggy Vacuum
Light on doesn;'t steam
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
170 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
