Question about GE Heating & Cooling
Heater/ac unit does not work after power surge during storm. Thermostat still works.
  • jtorbic Aug 06, 2008
    It has been out for about a day and a half.
    My unit is almost 2 years old. I was told it had a 5 year warranty. Do you know anything about warranties?
  • 182 Answers
There is usually a built in delay if power in interupted.Usually 5 minutes.
Posted on Aug 05, 2008
  • Dave Dobransky Aug 06, 2008
    Then it has shorted something electrically.You need a pro.
    yes i do.there is usually a 5 yr parts warranty.....you would be liable for labor.
Wall ac in off position plug in surge protector blows instantly
It may be possible the it has fried the surge protected internally causing it to short out or blow when plugging in. I would try using another surge protected if you have one or if possible replace the cord going to the unit with a new one and see what happens. Also possible that the outlet your using went bad during the storm as well. Don't know 100% but should be a couple tips to help get you going.
Aug 19, 2012 | Video Game Consoles & Games
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
Will not heat we replaced both elements but still no hot water rheem model no.82v522marlene we suspect we had a power surge during last storm because the furnace went out also at the same time
Hi I suspect your thermostat will have also been damaged if you had a surge I always replace thermostats at the same time as the elements
Also check the wiring as sometimes surges can melt the copper core of the wiring, but be careful always turn off the power first before any electrical works!
Mar 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Wii wont turn on, nothing had a lightning storm last night and now nothing
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
Feb 28, 2011 | Nintendo Wii Console
My APC350 backup ups has a overload when power is interupted with no load connected. The unit will start beeping but does not supply battery back up. The power supply to the battery shows 14.4 volts and...
It may still be supplying power but the surge arrestors were probably damaged by the surge. Go to apc.com choose support from the menu bar, they should be able to help or maybe even replace your unit.
Jun 06, 2010 | IBM APC Back-UPS Pro 350 (22P5090) UPS...
COMPAQ Presario v6000 Died during Tstorm
My 6000 also died in a thunder storm with power surges.  Power seems to be coming in to the cord, but the ON/OFF button on the front does not turn the computer on.  Totally black screen, with no response.  Hoping for help too.
Feb 27, 2009 | Compaq Presario S6300NX PC Desktop
Power surge
Unplug it then plug it back in and it should power up
Oct 01, 2008 | Philips DVDR3575H/37
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
