Question about Canon HV20 HDV Digital Camcorder
Can't turn on my HD 20 Sony handy cam. Power is working - charging battery but neither battery alone or the ac charger can activate the recorder in either Camera or Play mode. Please help me turn this on!
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Apr 02, 2011
Why is my sony hvr hd camcoder not switching on
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
So your saying the charger will charge the battery, as long as the laptop is off...But when it is charged, you remove the ac adapter, start up the laptop, running on battery power alone, then hook the ac adapter to it, and the laptop cuts off..???
Apr 27, 2014 | Acer Aspire 8930G Laptop Charger...
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
Camileo s30 not charging
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Mar 15, 2012 | Toshiba Camileo S30 HD Camcorder -...
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Sony handy cam dcr-dvd305 disc error 1302
This code refers to the power supply and batteries. Most likely, your battery has crapped out on you. I would go to the store and buy a new ome. Just be careful and take the old one in with you, since Sony makes about 5,000 different batteries, alot of them look exactly the same, but have vastly different voltages, charging rates, how long the battery will hold the charge, how may watts, amps, whether or not the battery can be recharged notmally or if it requires a special charger.
Dec 02, 2010 | Sony Video Cameras
Charging problem
If your computer runs correctly on AC power (without the battery), the power adapter is fine. So the problem may rest with your battery. If you have been using the same battery for 3-4 years, I suspect that it may not be holding the charge (end of life)
Try charging you battery and run the computer on battery alone and see how long it lasts.
Hope it helps
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Canon HV20 HDV Digital Camcorder Logo
54 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
