Question about Brother LS-2125 Mechanical Sewing Machine
The needle isn't picking up the bobbin thread and everything seems to be fine other than that...any answers? Thanks
SOURCE: Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Posted on Apr 15, 2007
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
SOURCE: brother ls2125 bobbin not picking up thread
you have the wrong size bobbin in ,its to high over the bobbin case causing it to rap around the bobbin.
Posted on Feb 10, 2009
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
I recently received a Juki TL-98Q and a long arm quilting machine. Everything is set up and I have put two sheets with cotton batting between them on the machine so that I can practice. I cannot get...
Hi Donna:
This has two parts; 1) pick up thread, and 2) needle hole direction.
1) To begin and pick up the bobbin thread, typically I start without any material under the arm. Begin with a tail of thread about 6" long pulled out from the bobbin, leave it loose. Then holding taunt, onto about 3" of the upper thread after it leaves the needle, I cycle the machine once. Then it should have captured the bobbin thread. Raise the pressure foot (with the needle 'UP') and slide something between that gap to pull out both threads (Upper and Lower), a ruler or your thread trimming scissors are handy for this. Pull the threads and you should see both upper and lower threads now, ready to sew. Apology for covering this basic item, but . . .
2) As you move into 'new' machines, sometimes the needle is no longer setup with the hole front to back. The gotcha is that on some (bigger) machine the hole goes side to side (yes the needle is rotated a 1/4 turn). As a rule of thumb, the thread goes through the needle and points right at the hook. Small machines may have the bobbin right 'behind' the needle. Larger machines often have the bobbin (and hook) beside (often to the right) of the needle. That means to install the needle with the hole going left and right, and the cutout groove pointed to the side with the hand-wheel.
End.
Oct 11, 2017 | Juki TL-98Q
It stopped picking up the bobbin thread while sewing. In the middle of a zig zag sewing project, it stopped picking up the bobbin thread. I cleaned the bobbin area and needle area and tried again and it...
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Sep 12, 2011 | Janome 2049LX Mechanical Sewing Machine
I have a singer inspiration4212 and I was sewing and a piece of materialwent down into the feed dogs and I had to tug a bit to get it out.Now my bobbin won't pick up the thread. I have taken the bobbin...
even if the needle is not bent, the needle could have a burr on the tip, I would try a new needle
clean under the needle plate & in the bobbin area for loose thread or lint
if the machine still does not work then it could be out of time
Aug 02, 2011 | Sewing Machines
The needle won't pick up the bobbin thread? Seems
I think you mean the shuttle is not picking up the top thread. There are many reasons why this can happen. The best way to find out which is to leave the cover off the bobbin compartment and turn the machine slowly by hand while watching things happen for a few cycles - best to have a piece of material in place as well (but not in your line of sight).
As the needle begins to rise, the top thread should form a loop for the shuttle to pick up. If no loop forms, the needle could be too fat for the thread, the thread could be sticking to the needle, the pick-up arm could be out of time (unlikely), or the thread tension could be wrong (or the machine not threaded correctly).
If a loop forms, but the shuttle does not pick up up, the needle could be bent (take it off and roll it on a flat surface),or in backwards (loop forming opposite to shuttle), or the material (or your manner of feeding it) causing the needle to be deflected away from the shuttle. On some machines, it is also possible to loosen a clamp and move the shuttle closer to the needle, but obviously that is a last resort (unless it has come loose or been forced away).
There are other possibilities, but usually it's the simplest thing. Try changing the needle?
Jul 27, 2011 | Elna Sewing Machines
My machine is new and worked briefly but now . . . . the machine is threaded correctly and the bobbin is placed correctly. When turning the knob for the initial pick up of the bobbin thread, it does not...
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Jul 14, 2011 | Singer 7444 Mechanical Sewing Machine
Needle thread will not pick up bobbin thread tried everything
Generally, this is because the needle is inserted wrong or because it's bent. In the first case, the top of the needle (called the shank) has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up the bobbin thread. Even if you think your needle is fine, change it to see if this solves the problem.
May 09, 2011 | Yamata FY700 Mechanical Sewing Machine
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
Needle will not pick up bobbin thread
Chances are you will need to retime it if you have checked everything else, if you email me with your make and model I can attach instructions
Mar 26, 2010 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
21 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
