I need a manual for Maytag M7DH65B2A dehumidifer. www.maytag.com didn't have anything on dehumidifers. Nothing came up even when I put dehumidiers and the model number. Is there another site to obtain a manual for Maytag dehumidifers? Thanks
  • 744 Answers
I wasn't able to locate an on-line manual. However, I did locate a place that shows a breakdown of your dehumifiier. There is also a number to call where you may be able to get a manual. See this link:
http://www.appliancefactoryparts.com/dehumidifiers/fedders/m7dh65b2a.html
Also see this link:
http://www.fixya.com/support/t3813188-operating_manual_m7dh65b2a
Posted on Apr 02, 2011
Why does my dehumidifer not work?
If it is not running because it thinks the bucket is full even when it isn't, the problem is that the float is broken or jammed. A replacement is no longer available, but you can find the small switch and tape it so it always stays on. It won't shut off when the bucket is full, but it will run. This assumes all the other panel lights come on properly - you didn't provide much detail about what works and what doesn't work.
Jun 24, 2014 | Maytag M7DH65B2A Dehumidifier
Dehumidifier fan
Please get the manual from http://www.maytag.com/support/manuals_literature.jsp
and make sure the settings are correct or adjust the settings.
Let me know if you need anything else.
Thank you,
Ekse
Jun 23, 2008 | Maytag M7DH65B2A Dehumidifier
Where do you find replacement parts when they are discontinued? I need a regulator for my dehumidifer a7dh45b2.
Fedders also made identical dehumidifiers for Maytag. Their model numbers are almost identical, and their parts are the same. So, try finding the parts you need thru Maytag.
Mar 26, 2011 | Fedders A7DH45B2A Dehumidifier
My dehumidifer kr923317 283w will not come on it just beeps
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
I have a Maytag model M7DH65B2A dehumidifier that has worked well for several years. However, when I hook up the hose to drain off the water when we go on vacation the water still fills up the built-in...
Hi Graham. Check the hose and the opening to the hose through the base of the dehumidifer. There is probably some debris in there causing this aggravating problem. J.
Jul 31, 2010 | Maytag M7DH65B2A Dehumidifier
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
White powder coming from dehumidifer.
Commercially available cool mist humidifiers sonicate water in order to create a fine mist. In other words, intense vibration liberates millions of tiny droplets of water from the reservoir. This water contains all of the salts of the original tap water. Consequently, over time, you will begin noticing that a fine white powder covers EVERYTHING in the room. This is the same stuff that is trapped in the reservoir of a warm mist humidifier.
its harmful but very annoying !
please rate me
May 29, 2009 | Maytag M7DH65B2A Dehumidifier
My dehumidifier looks working fine (normal condensor sound and light) but does not pick up water.
sound like a sealed system issue , if the compressor is running and no moisture is being deposited into the bucket there is an issue with the sealed system that need pro help
Apr 27, 2008 | Maytag M7DH65B2A Dehumidifier
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
