Question about Whirlpool Whispure 510 Air Purifier
Given a Whispure 510 (used I think) indicator lights say no need to replace filters but air smelled badly like cigarettes after a few mins use ( we dont smoke) is this fault in the "replace now" indicator?
3 Suggested Answers
SOURCE: it is not putting a good smell in my home, It
Icant smell any thing ,fan is working ,
Posted on Jan 29, 2010
  • 884 Answers
SOURCE: I have a squeak in my whispure 510 air purifier.
Spray lubricant onto the fan shaft as close to the fan body as you can. it will work it's way into the bearing
Posted on Apr 22, 2012
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Looking for a fan motor for this unit.
You have not supplied us with a model number, so, please type in "Sears Parts Direct" into your search engine, and supply them with your model number, and you may look at the schematic.
They will supply for a fan motor, if it is available.
If the machine is made in China, parts may not be available.
God bless your efforts.
Jan 05, 2016 | Whirlpool Whispure 510 Air Purifier
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
Apr 17, 2012 | Whirlpool Whispure 510 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
It is not putting a good smell in my home, It smells like cigarette smoke. I have a classic air purifier, and a newer model with ultraviolet light. They both do not put a good smell, in fact the one in...
Hello, To smell like cigarettes, you would have to be smoking ? I would recommend calling the manufacturer and describing this problem to them. Somethings going on, and I would start there. I hope they can be of help to you.
Good Luck, Shastalaker7
Nov 04, 2009 | Ecoquest Living Air Classic Air Purifier
Turn off reset button
IF RESET DOES NOT WORK DON'T WORRY
AS LONG AS YOU REMEMBER TO CHANGE
THE FILTER. CHARCOAL WHEN DIRTY AND
HEPA ONCE A YEAR OR SO.
Mar 19, 2009 | Whirlpool Whispure (45030) Air Purifier
Replace Filter Indicator Will Not Turn Off
I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
Whirlpool Whispure 510 Air Purifier Logo
Top Whirlpool Air Purifiers Experts
mike cooper
ray gallant
Think Crucial
Think Crucial
Are you a Whirlpool Air Purifier Expert? Answer questions, earn points and help others
