Question about Starbucks Barista Burr Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage for Starbucks, and learned grinder maintenance, but I must have forgotten this trick. Just can't seem to get it lined up and flush again. Thanks!
    New Friend:
  • 107 Answers
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Posted on Aug 28, 2011
Krups gx6000 grinder advertises removable burr grinders and there are no instructions, but is that the best way to clean them?
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
Jan 19, 2015 | Krups Gx600050 Conical Burr Grinder Black
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
How to clean burrs
Easiest way run a tablespoon of rice through the grinder.
Apr 25, 2010 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Was great for several years, but no longer grinds well
the best news is that the model is still on sale. http://www.starbucks.com nothing online about new burrs specifically but i am sure they will supply If you require a machine part, operational assistance or maintenance hints, please contact Warranty Services at 1-800-334-5553. Hope this helps :)
Nov 21, 2006 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
430 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
