Question about Disney 's Pluto Telephone
Can't get a dial tone, and the battery case, one of the batteries, won't stay in. WHERE CAN I get this fixed????
I cant get a dial tone to call out says line in use but I have checked and unplugged all 4 lines still no dial tone everything else is good no dial tone
Try:
Turn off power for the base.
Turn off phone and take out batteries.
Wait few seconds then put batteries back.
Will help if you unplug and plug the cables.
Jul 14, 2015 | Lands Phones
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
I have a philips telephone/fax machine with 2 handsets, the handsets have stopped working, there is no dialling tone and they won't let you reset them it tells you not possible. What can i do? thanks...
TRY UNPLUGGING...WAIT A FEW SECONDS, THEN PLUG BACK IN...THIS SHOULD RESET YOUR PHONES. IF THE BATTERIES ARE CHARGED!
IF YOU DON'T HAVE A DIAL TONE, YOU MAY HAVE A FAULTY PHONE BOX, (LOOSE WIRE ETC,.SOMEWHERE)
OR IT IS POSSIBLE YOU MAY NEED TO REPLACE YOUR BATTERIES, I WOULD TAKE THE BATTERIES OUT AND RE-INSTALL THEM IN OPPOSITE PHONES.
IF YOU COULD PROVIDE ME WITH THE MODEL NUMBER, I COULD RESEARCH THIS FURTHER FOR YOU.
ALSO...DO YOU HAVE A DIAL ON YOUR FAX MACHINE? IF SO...THEN TRY HOOKING YOUR PHONE'S UP TO THAT PHONE JACK...TO SEE IF THEY WORK!
LET ME KNOW...WHAT HAPPENS?
KIND REGRADS!
MARTIE
Sep 08, 2011 | Cell Phones
My cordless CD275 phones is not charging. It also ahad no dialing tone and won't make or recieve calls
The phone seems to have too many issues and it seems that the handset unit is faulty. check and see if the battery had leaked into the handset. If so it might have damaged the circuit board and it might be too costly to repair.
Also check the adaptor for voltage, check the telephone line input for a failed optocoupler - no dial tone or a switching transisitor or zener diode.
Jul 21, 2011 | Philips Cell Phones
We cannot get a dial tone on all three of our phones. We tried unplugging them from the wall, taking out the battery and waiting 4 minutes then putting back the power source and putting in the batteries...
Have you tried a corded phone that does not have any batteries? Unplug all phones and try a phone with no batteries one jack at a time.See if you get dial tone on the phone with no batteries.
Jan 11, 2011 | Lands Phones
No dial tone now
When there is no dial tone the problem could be dead batteries in your handsets, or an unplugged base, or a problem with the phone lines outdoors [which only the phone company can fix]. Check your phone first, then make sure the base is plugged in. If all is ok with your phone then call the phone company and tell them you have no dial tone. Regards, Joe
PS please rate my answer. Thank you.
Dec 20, 2009 | Uniden Cordless Phone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Disney 's Pluto Telephone Logo
Top Disney Lands Phones Experts
richie46
Tom Chichester
Are you a Disney Lands Phone Expert? Answer questions, earn points and help others
