Question about Ironman Exercise & Fitness
Just stopped working while using it Ironman Inspire or Flex 3
Ironman inspire board powers up but the motor will not start when the start button is pushed
see the video and proceed according for fix it. However if after you did LUBE the problem remain. TIME to replace the deck old board completely.see block diagram. God bless you3_26_2013_11_42_43_pm.gif
Mar 26, 2013 | Treadmill Doctor Ironman Inspire Incline...
Yurbuds making music sound digitized or muffled. sound unclear all of a sudden. 4 months old.
Email their customer service at info@yurbuds.com. They are quick to respond and will take good care of you.
May 18, 2012 | Yurbuds Inspire Ironman Series Earbuds Red
Ironman treadmill shows code SI 1. what is it? how to fix?
The SI 1 error code means there is no safety key in place. Unplug your treadmill, wait a few minutes, then plug it back in.
When you try to use it again, make sure the safety key is firmly in place, and make sure the metal piece below the Emergency Stop sticker is still in place.
If neither of these work, it may be appropriate to take your treadmill to a servicer.
Hope this helps!
Feb 21, 2012 | Ironman 220t Programmable Treadmill (225...
Im trying to figure out a website dats free to get the htc inspire unlock code or how can i get it
Dear friend, i suggest you to not to use free unlock code in your HTC INSPIRE. because free unlock code is not trusted to unlock your HTC INSPIRE.if you want to unlock your HTC. find your HTC unlock CODE here . this site offer cheap price to unlock code.i hope this will help you :)
Oct 03, 2011 | HTC Inspire 4G Smartphone
Watch battery died. Took out and then lost the factory original battery for my Timex Mens 100 Lap Watch Ironman Watch on way to store. Internal parts to watch don't say what battery number I need. You...
I have a 100 lap Timex Ironman Triathlon Flix watch. It uses a CR2025 battery. It is a thin 3 volt lithium battery. My original was a Panasonic battery. I hope that this helps you, Michael
Nov 17, 2010 | Timex Sports Ironman Triathlon 100-Lap...
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
The 'mode' button has stopped working on my times ironman stopwatch? Is it because the battery is running out or a more serious problem? Thanks
The most likely cause is obviously the battery. I don't think you can do much with electronic watches if anything else fails!
Feb 03, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Dec 19, 2009 | Ironman Exercise & Fitness
Timex Ironman IControl receiver not working.
Where can I get a receiver for my iron man i control watch. Lost it.
Jun 09, 2009 | Timex IRONMAN iControl Watch for Select...
Exercise & Fitness Logo
97 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Jim Dowell
Techmotionusa.com
Techmotionusa.com
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
