Question about Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE
My Alesis iPod Amp was charged and I plugged the iPod in and started playing the first song. Sounded great. Stopped playing after one song and now no sound will come out using any input device. Power shows on and charged. Tried with it plugged in and with just battery... any suggestions?
3 Suggested Answers
sonicboomele
  • 1557 Answers
SOURCE: After not using the Amp for 6 months, I plugged in
the system has burned out you can have it repaired but depending on the damage i would replace it
Posted on Mar 01, 2011
  • 67 Answers
SOURCE: My Alesis Interactive Mobile Amp seems to have a
change the battery, its quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
Posted on Nov 07, 2011
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
I have a silver ipod classic 16GB, and it was my cousins but he rencently got an iPhone so gave his classic to me. Im not sure how long he has had it for but when i started using it the first time i...
Yes, This problem is generated by battery. If Battery is dead iPod Could not start.
Contact Nearest apple care center & replace Battery of your iPod & i will start.
I am very happy to assist you.
Thanks.
Oct 10, 2009 | Apple iPod classic MP3 Player
Hi my apple ipod shuffle 1g wont charge.. or play songs
You are supposed to transfer songs usin itunes....simple drag and drop doesnt work.... You can download itunes from www.apple.com\itunes
If you are already using itunes,perform a restore on the ipod using itunes...you will find restore option under the summary tab in itunes.
Sep 29, 2009 | Apple iPod shuffle MP3 Player
My Ipod Shuffle won't play.
that`s not the reason.your Ipod have some problem with the firmware.connect your ipod to itunes and select reset.make sure you reset through itunes.you`ll lose songs on the ipod but it will work.
Jul 15, 2009 | Apple iPod shuffle MP3 Player
How do I use this amplifier to amplify an ipod?
minimize ur ipod volume to the lowest & disable bass boost or lower the bass in the ipod,control vol by the amps knobs,play higher kbps songs on amp
Jul 09, 2009 | Alesis RA-150 Amplifier
My Alesis transactive mobile PA system will not charge. I plug it in and the charge light does not come on???
Surprisingly, there is a little compartment just in the outtlet intake in the AMP, and the 10amp fuse was burned. I replace the fuse for a 10amp new one and everything work great. It charge. The little green light of charging, turns on.
Jan 01, 2009 | Alesis TransActive Mobile PA System...
My ipod 2gb need help!!!!!!!!!!!
Please restore it and check
Oct 11, 2008 | Apple iPod nano
Broken iPod
speakers have been known to do this, your headphone jack more than likely needs replaced
Jul 19, 2008 | Apple iPod MA446LL/A MP3 Player
Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE  Logo
50 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
