Question about Whirlpool Washing Machines
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
  • Whirlpool Master
  • 2,180 Answers
Put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Posted on Apr 02, 2011
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Dec 25, 2008 | Whirlpool Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool washer LSQ9549LN0 problem
    you have a problem in the transmission of the washer
    May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    144 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
