Hoover Performa Eco 1300 - When wash programme selected and power button pressed in to 'on' the trip blows on our main house Consumer unit. When we moved the machine out it seemed to work ok and now its doing it again. Any ideas?
5 Suggested Answers
  • 653 Answers
SOURCE: Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Posted on Apr 21, 2009
SOURCE: user guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Posted on May 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Hoover Performa ECO 1300. The washing is
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
SOURCE: When I switch on the
i have a hoover performa 1100 washing machine and just like the other man my machine trip the mains switch when i plug it in . i have tested it only without the water hose s not connected its trips the mains electricty when i plug it into the mains and even if the on/off switch is in off position as well
Posted on Aug 11, 2011
Hoover performa 900 model number washing machine user guide
Check out this site and see if you can find your model number of your machine.....http://www.whitegoodshelp.co.uk/washing-machine-instruction-books-and-user-manuals/
Aug 25, 2014 | Washing Machines
Washing machines
you can siphon the water out with a hose (garden etc.)
Apr 30, 2012 | Hoover Washing Machines
When I switch on the On/Off button the machine trips the mains electricity. It is a Hoover Performa 1100 Washing Machine
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 09, 2011 | Hoover Washing Machines
Apr 21, 2009 | Washing Machines
User guide for hoover performa eco 1200
Mar 26, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
I have a Hoover Performa ECO 1300. The washing is not being rinsed properly and there is washing powder residue still on the clothes.
8. re-try.
Mar 15, 2009 | Washing Machines
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Hoover performa 1300 door latch
my hover performa 1100 door latch will not open can anyone help
Sep 04, 2008 | Washing Machines
6kg Load Button
For a full load within 6kgs you dont do anything, just let it go thru the cycles. But when your load is half - you press the half load button. Good luck.
Mar 13, 2007 | Hoover AI130 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
