Hi, I have a HP 7500A Wide format All-In-One E910 network printer, scanner, fax... It was working just fine until I unplugged it to move it over 2 feet. I did not bump anything or drop it! :-( Now, on the machine, all I get is a blue screen with white printing showing 83C00009. I have unplugged and replugged. I have run all the diagnostics on the HP site. I have unplugged and turned off the modem, computer, etc. I have followed all the instructions that I can find anywhere and nothing is working. What else can I do to fix this? Please help!!!!
  • pam8825 Apr 03, 2011
    The link much be wrong since it just went to a page of ads. That isn't helpful! LOL
SOURCE: HP PSC 2210xi all-in-one won't print....Please HELP!
I had a problem downloading HP psc 2210 software from the internet after a reinstall of winxp. One of the device drivers was not completing its installation. HP support provide a troubleshoot process to fix the problem. This process is manual but did complete the installation of the device driver. The printer is working.
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: Lexmark 4200 Series printer/fax
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Posted on Mar 20, 2008
  • 138 Answers
SOURCE: hp laser jet 3055
You have a formatter issue (motherboard) on the printer. Sounds like you took a surge possably through your telephone line.
Here's a couple things to try and re-initialize the machine.
Soft Reset: Press "Menu", then press * and # simultaniously to enter the developer menu section. Press the "> or < until until REINTFFS is displayed on the second line of the display. Press the "Check button". The machine will go through a series of checks and flash different things. About 2 to 2.5 minutes later the machine will return to ready.
If that doesn't fix it, here's the next more aggressive reset but caution as this will reset all your settings and you will have to reset up everything (language, phone numbers, country code etc..) after using.
Super NVRAM Ret:
Turn off machine, Press and hold down * and 5 while turning on machine. Continue hold down throughout the power up sequence. When PERMANENT STORAGE INT is deplayed on the display, release the buttons. When prompted, set the language and telecom region.
To set the language and telecomm region, the machine will prompt for them when they have been erased. Simply use the > or < until its correct for your language and then press the "check" button. Same process for the region. Once both have been set the machine should come to READY.
If neither of the above works, you will need a professional tech to resolve the issue and possably replace the formatter board.
Hope that helps you.
Posted on Aug 26, 2008
mspcrepair
  • 169 Answers
SOURCE: hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: 3030 hp all in printer scanner problem
please open the machine and reinsert the white strip again to mother board
Posted on Nov 08, 2008
I am trying to find the touch screen control panel for a HP 7500A wide format
I am sorry but this site doesn't sell parts or have any way to look them up for you.
Oct 31, 2016 | HP Officejet 7500A Multifunction Printer
How to remove driver and all files for HP Officejet 7500a E910 Multifunction Printer
go to control panel of pc , click installed programs , click on hp printer to high light it , right click to uninstall
uninstall all hp programs listed one at a time
Nov 07, 2015 | HP Officejet 7500a E910 Multifunction...
Though i have no paper jam, it keeps on prompting Clear paper jam then touch ok. Also notice the carriage not moving from right to left ,its making a weird noise.seem paper feeder gear stuck but clear
Hi vidya kowlessur,
I would be happy to help you with your Officejet 7500A printer. I understand you are seeing a message prompting you to clear a paper jam, and the carriage is likely jammed. Please use the following 2 documents to troubleshoot the issue;
HP Officejet 7500A E910a and E910c Wide Format All in One Printers Out of...
Carriage Jam or 0X610000F6 Message Displays for HP Officejet 7500A E910a...
I hope this helps, but if the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 09, 2015 | HP Officejet 7500A Wide Format...
Where can I get a service manual?
Hi Julio Vargas,
I'd be happy to help you with your Officejet 7500a. I am not sure if I can provide you with a service guide, but here is a link you can use to access the Setup Poster, user Guide, and Getting Started Guide:
HP Officejet 7500A Wide Format All in One Printer E910a Manuals
If there is something more specific I can help you with please let me know.
Thanks,
Lisa.
Jun 18, 2015 | HP Officejet 7500A Multifunction Printer
How do I attach a hard copy to an email- HP Officejet 7500 E910
scan it to a file
Find program called hpscan in your list of all programs to scan to file.
This is usually what it is called with hp scanners
Note the directory that the file is scanned and saved to .
and then attach file to email message using attach file option on email program when you compose email message.
Apr 09, 2014 | HP Officejet 7500a E910 Multifunction...
Hp 7500a e910 doesn't save
Please , you mean tif , anyway you can save to JPG then convert it by any other software , but i think scanner does support like your file ,
I hope was it helping you
Mohamed Hejazi
Afaqnama-LIbya
ipg@hplibya.com
Mar 03, 2013 | HP Officejet 7500A Multifunction Printer
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
235 people viewed this question
jasbo
jasbo
