Question about Crosley Dryers
Crosley Heavy Duty Giant Dryer. Drummer won't turn. One belt looks fine. Is there another belt?
wbwill
  • 68 Answers
SOURCE: kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Will
Posted on Sep 16, 2008
  • 10865 Answers
SOURCE: sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Posted on May 12, 2009
  • 1122 Answers
SOURCE: Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Posted on Jun 23, 2009
Maytag317
  • 1136 Answers
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
Hi, To get to the belt, remove the screws on both sides of the door opening. The dor will lift off. Pull on the front panel and set it off to the side. You will need to remove the front panel holding the drum up. It is not a hrad job but, another set of hands to help makes a difference.
I have a pic of you dryer but it doesn't show a good view of the back. Some models have an access panel to make it easier to finish putting the belt on the idler pulley and motor pulley.
It is tricky when you have to put the belt on reaching in from the front.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 10, 2009
  • 2333 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
Crosley heavy duty dryer blows out heat but will not spin
Check the dryer drum drive belt it may be broken or the dryer drum drive motor may have failed
Oct 18, 2016 | Crosley Dryers
We have a heavy duty crosley and recently it's starting to squeak and when when started and running
Hello amber mallette, thank you for your post!
From my understanding your Crosley dryer is squeaking once it starts running. This could be a possible problem with your belt, pulley, or motor. You may need to disassemble your dryer in order to access those components. This is not a simple DIY job. I would highly recommend having a professional technician out, this will help to avoid any future issues or personal injury. Hope this information is helpful. -Matt
Feb 25, 2015 | Crosley Dryers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Where is the heating element on a crosley heavy duty giant capacity plus
The element will be at the back of the dryer behind the drum I will give you a link to a video that will show you how to do this .It is not a hard fix and takes 15 to 20 minutes..
Jul 04, 2012 | Crosley Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
I have a Kenmore 80 series Heavy Duty Quit Pak Dryer and it won't turn on. No sound or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore Dryers
We took our heating element out of our dryer and didn't mark the wires. Is there somewhere I can download a map of where the wires go? It's a Crosley heavy duty giant capacity.
How many wires do you have? If only two, the heater element doesn't care which wire is attached since it is being fed with AC current there is no polarity to it.
Oct 29, 2009 | Crosley CDE6000 Electric Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
Dryers Logo
16 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
