Question about Garden
How do i get the bit out of dewalt dw272 so i can repace wit a new 1
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Magnetic Extension for Dewalt Drill Bit
I have the same problem and am thinking of cutting that extension to get it out. A real pice of !@#$$%
May 13, 2012 | Dewalt DCF815S2 12-Volt Max 1/4-Inch...
My dw272 type4 don't work with new brushes
in most cases we have seen with dewalt drills the fault is corrosion around the power points to the motor they snap off if this is not the case then it will be the trigger switch
Jan 03, 2011 | Dewalt Drills
I have a new DeWalt DC725 cordless compact 1/2" drill/driver/hammerdrill. The only problem so far has been that the keyless single sleeve chuck will now not open to release a 1/2" drill bit. I have twisted...
place the bit in a bench-vice and take a little benchhammer and with a plastic hammer .
hold the hammer with chisel tip on the claws of the chuck and tap with the plastic hammer on the other side of the bench hammer and beat gently on the three claws tighten the chuck three-step around gently around so the bit slowly from the drill bit comes slowly loose.
if the bit is out you can turn the chuck free, if this problem repeats go to the dealer for warranty .
Aug 17, 2010 | Dewalt Garden
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Thanks for using FixYa.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
How to put bits into chuck of dewalt d25303kr otary drill?
should just push them in, you may have to turn the bit around til it will engage, but that is all you should have to do
Jan 01, 2010 | Dewalt 1" Sds+ L-shaped Rotary Hammer...
Having trouble changing dewalt 14.4 v xrp cordless drill bit
hold black chuck and put in reverse if dont work spay wd 40 in and around where drill bit goes and let sit a few hours
Sep 12, 2009 | Dewalt Heavy Duty XRP 1/2" 14.4v cordless...
DW272 switch wiring
I would go to the mfr's website and download or look at the wiring breakdown. All these companies have breakdowns online
Nov 13, 2008 | Drills
Garden Logo
274 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
