Question about John Deere A,b,g Tractor Carburetor Float Dltx10
My John Deere 345 tractor starts okay, but only will keep running if I hold the choke on. I changed the oil filter, air filter, spark plugs and added fresh gas and it still won't keep running.
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
nova2nv
  • 197 Answers
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
Posted on May 22, 2010
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
Mower only runs with choke held open
Have you cleaned filter on carb unit? My filer gets plugged with dry grass and does this. I have to remove filter and clean out grass even though the cover is on tight, don't know why but it does. Hopes this helps.
Sep 23, 2014 | John Deere Tractor Starter 285 345 2243...
John Deere will not start. fuel filter dry
some models have a fuel pump some are grivitey
May 03, 2012 | John Deere Garden
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere A,b,g Tractor Carburetor Float Dltx10 Logo
820 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
