Question about Refrigerators
What are the first steps for troubleshooting a freezer that has stopped working?
  • Refrigerators Master
  • 2,183 Answers
First off what's the brand name and model number of the machine,if it's a G.E. i'd go right for the computer board,if the freezer is warm most likely it's a compreesor problem or the compressor isn't running from maybe a bad board or a timer or a freon leak in the system or a bad compressor,you have to let me know if the compressor is running,if it is you could have a freon leak,you can remove the freezer inside back wall,look at the evap coil,if there's just ice on the top of the coil and not an even frost pattern covering the whole coil you deffinetly have a leak in the system. if it isn't running you could also have a bad start device on the compressor but like i said i need the model number and a little more info and i can help you out.
Posted on Apr 02, 2011
  • 8,220 Answers
Not much to a freezer. I would first check to see if the freezer was possibly stuck in defrost mode. I would find the timer and advance it manually to see if the freezer kicks back on.
If the timer turns out to be ok I move onto the next step which
is to check the compressor relay.
I feel the compressor; if it is too hot to touch the relay is fried together, if it is cold to the touch the relay has fallen apart. If the compressor and timer are ok I next check the cold control. If it is open (no continuity) then it is bad. If all of that is good then I look for defrost prblems. If the heater or terminator goes bye bye then ice will form and block the fan that blows the air into the fresh food compartment.
More Here
Trouble shoot Frigidaire upright freezer?
Thank you for your inquiry, friend!
Please help me understand if the question you are asking. Are you searching for general troubleshooting? Is your freezer currently experiencing an issue? With any additional information I would like to further assist you with any troubleshooting steps available. I look forward to hearing back from you. -Matt
Sep 25, 2014 | Frigidaire Freezers
The refrigerator side is not working, but the freezer is on my side-by-side
http://www.applianceblog.com/manuals/16025628.pdf
Here is a manual with decent infomaiton and troubleshooting tips. Since I can't walk you through each step of the troubleshooting process and see the results on the meter, I hope this will help you some.
Are you getting an ice build up behind the panel in the freezer compartment? If you are then check out the defrost heater, defroster thermostat and the defrost timer.
Since the cooling unit is on the freezer side, it moves the cold air to the refrigerator side with a fan and cooling tubes. If the tubes get blocked or the fan stops working then the refrigerator side will not cool down.
Please feel free to ask anything you don't understant and I will do my best to answer you.
Jun 10, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
The fridge is all working ok the freezer is all working ok but the ice maker is not working i have removed the tube that goes to the water part at the back and blew down it an it is not blocked
Hi and welcome to FixYa, I am Kelly
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Ligt stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
Here is a link to the steps on how to troubleshoot an ice-maker.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Let me just add that many ice-maker related problems are due to the freezer temp rising above 16 deg F. The freezer starts warming up due to ice build up on the evaporator coils and then the internal air-flow is blocked by the ice build up causing the temps to rise. Look closely at the back of the unit for any signs of ice build up.
If you see ice build up......
1. Unplug the unit
2. Remove the freezer contents
3. Place a fan directing air into the freezer for just over 2 hours. (Water mess!)
4. Clean up the excess water and restart the unit. (Add freezer content)
5. After 8 - 10 hours check for ice production.
If after doing the above you have ice production then most likely you have an automatic defrosting problem.
If it still does not make ice, the steps in the link above will isolate what has failed in the ice-maker.
Before testing the ice-maker using the steps in the link.. I recommend you peform a manual defrost with a fan. If 8 - 10 hours after the manual defrrost you do not have ice production,, use the link and troubleshoot the ice maker.
Thanks for choosing FixYa,
Kelly
Jan 31, 2011 | Refrigerators
Refer not cold, freezer is?
http://www.managemylife.com/mmh/owner_manuals/16224/KENMORE-Bottom-Mount-Refrigerator-L0306154?brand_name_search=73503
go to the troubleshooting operation food temperture appears too warm. if follow step by step no work. please check the evaporator coil. if it cover by frost or ice. i am sure the heat element or defrost thermostat is bad
Jan 10, 2011 | Kenmore 73503 Stainless Steel Bottom...
Freezer stops making ice. when it is cut off it starts again and then stops
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | GE GTS22WCP Top Freezer Refrigerator
Freezer stopped working suddenly
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 30, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
How to troubleshoot walk-in freezer & chillers
Good day,
The first step is to check to see if the fan motors in the evaporator cooling assembly are blowing.
The second step requires the use of compound gauge set. You will need to determine what type of refrigerant the unit runs on and what the high and low pressure readings are when the unit is on and running.
Mar 31, 2010 | Freezers
Dometic model 3663 top freezer works great bottom warm only goes to 50 . have checked flu, flame, gasket seems ok
Here's a good troubleshooting step-by-step process to help identify and resolve the problem you're experiencing.
http://gasrefrigeration.net/does_not_get_cold.htm
Hope you found this helpful and best regards!
Jun 30, 2009 | Dometic NDR 1292 Refrigerator
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
