Question about Acer Aspire One PC Notebook
HOW DO i SWITCH FROM CANADIAN FRENCH TO CANADIAN ENGLISH KEYBOARD
  • 2,229 Answers
In the control panel there are regional and language settings. Try there.
Posted on Apr 02, 2011
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
Keyboard s typing blue numbers, how do i switch back
Dear Sir,
You must have accidentally changed your comps type setting from english to 'canadian french'. at the bottom right-hand corner of your screen, there should be a small picture of a keyboard, click on that and switch back to US.
Thanks For Your Time,
Apr 08, 2010 | Gateway 2520915 Keyboard
Why are some of my keys showing É or é
sounds like your keyboard is speaking another language. Go to control panel, regions, and make sure that English is selected.
Dec 05, 2009 | Acer NSK8458AN Keyboard
Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
Sep 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a Canadian keyboard, when I press the letter Q, A shows
If you are wanting the keyboard to type as English, then you need to reinstall windows and set you Country of Residnce to England or USA English
Jul 15, 2009 | HP Pavilion a1730n (RK574AA) PC Desktop
When typing question marks & puctuation...French comes up
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English is selected as the Default Input Language. If French is listed as an available keyboard layout and you don't need it there, you can remove it to make sure it doesn't switch itself again.
I hope this helps. Good Luck.
Jun 24, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
When i type the@ symbol i have to use the '' button.also cannot type the pound sign as # comes up. please if you can help thankyou. regards annette.
Hi guys,
I see a couple people are having the same problem. This is a problem we see often in Canada due to the bi-lingual nature of the country.
Depending on where in the world you are located these instructions will vary slightly, but you can figure out which country you live in and what language options you see available on your keyboard.
Sandy has given some good general advice, thank you Sandy. However, my living in a region with this issue I think I can top Sandy's solution off with a bit more advice. The problem is if you live in an area with one or more dialects of the same language(Arabic, Chinese and English being of note) there are several correct options to pick for your keyboard. I will use canadian computers as an example.
Quite often when customers buy a PC from me they go home and upon turning them on answer the location questions as Location: Canada, Language English(Canada), Keyboard: English(Canadian Multi Lingual, Canadian French or Canadian English) not realizing there is no Canadian Keyboard design for strictly English, they all have some variant of French Accents embedded. The proper answer to the last question(unless it actually is a multi ligual or french keyboard) is US English as that is the keyboard 90% of Canadians use.
Both of you seem to have the same problem, wrong keyboard setting.
To change the setting, go into the Start Menu, Open Control Panel(may be inside settings menu in XP), then switch to Classic Mode using the link in the top left corner if you don't have more than 12 icons present.
Once you have the full list showing, click on Regional Settings or Regoinal and Language Options.
When this window opens, Select the Languages Tab(XP) or Keyboards & Input Devices tab(Vista).
There will be a button (Details in XP) that allows you to see the installed Keyboards. Once the Keyboards window opens, Ensure your Keyboard(US, UK, CAD) is installed, if it's not on the list, click Add and find it on the list, then click OK.
Once you are sure your keyboard is installed, remove all other Keyboards by selecting them then clicking Remove.
When the proper keyboard is the only one left, Click Ok on that window and on the Regional menu.
This should resolve your issues unless of course you accidentally select the Farsi Keyboard in which case you can redo the above steps to resolve the problem.
Hope this helps FixYa,
Chris
Apr 22, 2009 | Computers & Internet
KEYBOARD PROPLEM
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Chris
Model info for your product can be found at www.hp.com click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
Apr 11, 2009 | HP Computers & Internet
Logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Aug 20, 2008 | Logitech Computers & Internet
Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
May 22, 2008 | Acer NSK8458AN Keyboard
Acer Aspire One  PC Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
