Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and forward into the hot water lines. I am thinking that because of the excessive heat, the CPVC pipes attached to the unit are swelling and about to burst, which by the way has already happened twice... if unit does shut down before tha pipes burst, both the flame and the pilot light go out... any suggestions on what the problem may be?
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 02, 2011
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
Sep 24, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
Water is only getting warm with aquastar 125 bng model. It just started getting warm and not hot. What could be the problem?
Insufficient gas presure. Check gas presure exiting regulator exrternal of water heater. If presure is at 3.7-inches water column gas valve is defective.
Jan 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch 125 BNG gas tankless water heater. Pilot light will not light but spark is there. Solution and where do I get parts assuming needed.
Check and be sure gas knob is in the pilot lighting position and pushed in. Try to manually light with a match. Make sure gas **** is in the on position. Posible air in the gas line. Bled off air. gas valve or regulator has failed..
Jan 04, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
My aquaStar 125 BNG,will not shut down automatically when water turned off.
The water valve may be dirty and sticking, prohibiting it from fully closing the gas valve. This part needs to be periodically serviced (every 2-5 yrs depending on water quality and use) Purchase a water valve rebuild kit to service water valve.
This answer is off the Bosch site.
If this answer is not satisfactory, do not feel obliged to accept it!
Gary.
Dec 22, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
1,213 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
