Question about Motorola Mobility Defy Cell Phone
My mb525 uses abt 50 pct of the battery using standby radio. the radio app is off but still using battery. i can not find how to kill the fm radio. assistance is appreciated.
  • 6,784 Answers
HI.
You can easilly kill the process by acessing the taskmanager in droid. This will expose the process so that you can kill the program.You can hold the home button to pull up the recent task window, then, touch the task manager button to access the running processes in the background to kill what you need to kill to preserve battery life.
Posted on Apr 02, 2011
How can I use the FM radio in mySamsung Galaxy Tab A 9.7?
The Galaxy Tab A 9.7 does not have a functional FM radio, however it does have the functionality. It is typically disabled by your provider. You can try to get past this by downloading the NextRadio app, which can be found here: https://play.google.com/store/apps/details?id=com.nextradioapp.nextradio
Dec 29, 2016 | Tablets & eReaders
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
How do I stop mobogenie from downloading onto my Motorola Defy Mb525?
Go to the setting,in security or developer option you will see render script.disable it
and also instal non market app=disable it
Jan 23, 2014 | Motorola Mobility Defy Mb525
Mb525 volume loss?
In the standby screen, press and hold the # field to see if you can get back to try more than two
Aug 31, 2012 | Motorola Mobility Mb525 Mb526 Defy Plus...
I just got grunding 800 radio,no reception either am,fm ,sw please help me.
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
Aug 11, 2010 | Grundig Satellit 800 AM/FM/SW Radio
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
May 04, 2010 | 2006 Subaru Forester
My ICF-7600D shuts off after a random time of use. The Timer function is not used. Happens with internal batteries or with external power supply. Computer batteries are OK. Thanks.
Not sure of the actual problem but try not to actuate the sleep function or the standby as this may cause the radio to turn off at intervals. I have the ICF2003, same thing.
Feb 07, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
My Sony ICF-SW35 AM/FM/SW Radio is not staying on-
Download user manual of ICF-SW35 Sony Radio from Sony Support and hope this will help you to turn on the unit.
Thank you.
Nov 19, 2008 | Sony ICF-SW35 AM/FM/SW Radio
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Motorola Mobility Defy Cell Phone Logo
172 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
