Question about Maytag MBB2256G Bottom Freezer Refrigerator
I have a Maytag model MMB2256GEW refrigerator with a freezer drawer on the bottom. The problem I've been having is the drawer doesn't make a good seal on the right side only, which causes it to frost and ice on the right side and bottom of the freezer. I purchased a new gasket, but that didn't solve the problem. I also noticed the freezer seals perfectly when I remove the basket, which removes the weight from the drawer. Can you suggest a solution?
  • bossoxfan200 Apr 03, 2011
    Not part #18. It's part #20. Or maybe the combination of both. I'll do the checks you suggested, but I didn't see anything wrong with the right support bracket with it installed. I'll take it off and see how it looks.
    Thanks!
    President:
  • 1,216 Answers
As per your explaitions i can say that you had your gagket not fitted well so if you cannot do it yourself it requires someone with more experience than you.If you are sure that gasket is perfectly fitted proceed next.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Apr 03, 2011
    Guru:
  • 262 Answers
Here is a link to your freezer basket area.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBB2256GES/3048/0161000/M0403064/00005?blt=06&prst=&shdMod=
Is the basket part number 18?
If it is and the issue goes away when removing the basket then the issue has to be the basket.
The door is sealing and must be aligned properly or it would not seal.
Check the side slides where the basket is mounted. Ensure they are rolling back all the way for clearance of the basket. Note the left hand side then ensure the right hand side is going back as far as the left.
Ensure they are rolling freely without any restrictions. Ensure there is nothing in back of the basket to stop it from closing all the way.
Ensure the inside of the door has nothing that will interfer with the basket. Food,packaging,a shelf may have come loose,etc.
Ensure basket is not damaged in either the back or the front part.
If you have not found anything then take off the right hand side support bracket and inspect for any damage....try putting pressure on it to ensure that it will be mocking the weight allowing the sliding back and forth that happens when you open and close.
Do simulations with the basket in place rolling it back and forth....ensure there is as much weight in it as usual.
The answer to the problem is in the above....you just have to be a good detective.
Please post results.
Keith
Posted on Apr 02, 2011
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Ice is forming under the freezer drawer what causes this
Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
Apr 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Ice block at back of bottom freezer
the freezer heater needs replacing, it's about $50.00 bring the model number to your local part place retailer. and they can seld you a new one.
Dec 12, 2008 | Refrigerators
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag MBB2256G Bottom Freezer Refrigerator Logo
114 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
