Water will not drain and I get a SUD warning - Washing Machines
  • 415 Answers
Time is what it will take, let it stand and after some time has passed select the drain cyc. Now are you using HE soap if not your using too much of your old brand, and reduce to 1/4 cup if insistence on non-HE soap.
Posted on Apr 02, 2011
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
Aug 26, 2014 | Washing Machines
I have a Kenmore Elite QuietPak 2 front loading washer..lately it has been taking FOREVER to finish a cycle (always stalling at 0:01 when cycle is about to end) Suggestions??? I am also using HE detergent...
Where you able to check the operation of the drain motor when yo removed the filter for cleaning?
If not please see the extract of my guidance notes ;-0)
REMOVE POWER
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 25, 2011 | Kenmore Elite 45986 Front Load Washer
My washer keeps saying SUD. what is wrong?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 31, 2011 | Washing Machines
F2 code
Hi
Daniel
Jan 01, 2011 | Washing Machines
Washer displays Sud and will not drain. We waited 20 mins and then "reset" the power and the machine. Put the machine on drain and Sud is again displayed. My thought is that the machine is blocked...
You are using too much soap. Sud warnings are telling you the motor is over heating due to excessive amp draw on the motor from trying to get them suds under control. You must only use HE soap and sparingly. Remove the bottom panel and open the cleanout. Wipe it down and flush it out. You will find the tech sheet in there. It will give you the ability to diagnose the problem as well as a list of fault codes.2f6a2ac.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps saying SUD checked my detergent... it's HE safe?? have even tried no detergent at all but washer keeps saying sud
Remove the bottom front panel. Clean out the drain filter located in the front center.
Replace the drain filter.Run a cycle with all COLD water.
Apr 18, 2010 | Kenmore 43142 Front Load Washer
Water keeps running through every cycle of my Duet Front Loader.
You most likely have a bad water fill valve. The suds warning is likely because it is too full.
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
