Question about Gateway NV5378u Notebook
I have a Gateway laptop that refuses to do anything. No power, no lights. Nothing. The power brick is good, it puts out the right power. I've pulled the battery and tried running the laptop without it. No luck. I'm positive that replacing the motherboard would take care of this. I'd like to know if someone out there has encountered this issue before and was able to isolate this to any particular component.
  • 2,229 Answers
There could be one of two problems here.
The DC-in jack could be bad on the motherboard. If you're competent with a soldering iron you could try replacing that.
Otherwise, I'd say you're looking at a new motherboard.
Posted on Apr 02, 2011
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
It shutdown as it informed because the battery was almost dead. I had it plugged in but plugged it in other places too in case it was the plug. After that it refused to power up and the power cord didn't...
This is a problem Gateway laptops can suffer from. Try running the laptop without the battery and just plugged into the mains. You may find the laptop will work ok with just a new battery on it but its difficult to say. It can be an expensive gamble as laptop batteries are not cheap.
Apr 23, 2011 | Gateway M-6750 Notebook
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
Gateway ma7 will not power up
Gateway MA7s have dodgy DC sockets. Poor solder joint on +ve pin = increased resistance = lots of heat = burnt PCB around +ve pin usually shorting the +ve pin straight to ground. If you're lucky you might still be at the poor solder joint stage and the DC socket might simply need replacing and/or re-soldering. If not, it could be a burnt PCB and it's a pain to bypass the burnt areas due to how the power gets distributed around the PCB.
Apr 18, 2009 | Computers & Internet
My mx6128 is dead
Check and see if your power brick's light is on. The power brick is that black block of plastic on your power cord. If that light is dead then the power brick is bad. That should be your first item to check.
Apr 02, 2009 | Gateway MX6128 Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Power up
Try this first, take the battery out of the laptop. Make sure the AC Adapter isn't plugged in also. Then, press and hold the power button on the laptop for about 30 seconds. Put the battery back in and turn it on. If your still not see anything, or you can just barely see some images, it could be the back-light on your LCD has gone bad.
Jun 24, 2008 | Gateway CX2724 Notebook
Gateway 400sd4
You should try plugging in an external CRT or LCD monitor. Most laptops will automatically enable this port when you connect a monitor and reboot, but you may need to hit some combination of keys on the laptop if you don't see anything.
You should try this to see if the laptop is running properly other than the internal LCD or VGA hardware.
Dec 16, 2007 | Gateway 400SD4 Notebook
Gateway NV5378u Notebook Logo
192 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
