Question about SMC EZ Switch SMC-8024L2 24-Port Gigabit
Cannot log into the SMC8024l2 switch via ethernet or console and after resetting to factory defaults still cannot ping the device at the default IP Address or the IP address it was set up on.
    New Friend:
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
Posted on Aug 14, 2013
5 Suggested Answers
SOURCE:
MSG-CPC
  • 1325 Answers
SOURCE: How Can I reset the
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Posted on Nov 05, 2010
  • 1755 Answers
SOURCE: Trying to connect to my
Hi, Pull the plug for 30 minutes. This will reset router and then restart computer. Good luck.
Posted on Aug 04, 2011
jgroves705
  • 536 Answers
SOURCE: reset factory default
Find the "RESET" button on the back of the device, and press and hold it for 15 seconds to reset to factory defaults.
Posted on Feb 20, 2012
  • 126 Answers
SOURCE: what is the default IP address?\r\nCan its IP be
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Posted on Aug 16, 2010
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
I secured my wireless a few years ago and forgot me password to connect what can i do
You can reset the device to the default factory settings by holding down the reset button for 7 seconds. The default password is blank.
Now you can log into the router using an Ethernet cable, the default IP is 192.168.2.1.
May 05, 2011 | Belkin (54G F5D7230UK4) Wireless Router
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
Cant find my network connection key
You can get this by logon on to the router via web interface. www.netgear.com has detail instruction on how to do this
Dec 25, 2010 | NetGear DG834G Wireless Router
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
Cannot connect web console thru http
Pushing the reset button on the front panel should reboot the firewall and reset firmware to factory default. Do not hold down the reset button, this will change the IP address of the box.
Jun 30, 2008 | Barracuda Networks Spam Firewall 300...
DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Jun 20, 2008 | D-Link DES-3226L Networking Switch
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Not communicating
I would check the IP address/subnet mask/ default gateway information and make sure it is correct for the network is on. Then, I would check to make sure that the IP information is valid for the VLAN for which the management interface is assigned. It may be easiest to reset everything from the console and redo the configuration from scratch. Below are several documents that should help you do that. Device Documentation. http://www.symbol.com/legacy_manuals/wire/ethernet.html Quickstart Guide ftp://symstore.longisland.com/Symstore/techpubs/manuals/wireless/pdf/6844601a.pdf Admin Guide ftp://symstore.longisland.com/Symstore/techpubs/manuals/wireless/pdf/6844501a.pdf I would review the sections that pertain to setting the IP address and other management features. I could not find a section on reseting the switch to factory defaults, so you may have to contact their support staff for that. http://www.symbol.com/category.php?category=862 631.738.6213 or 1.800.653.5350
Sep 16, 2006 | Symbol ES 3000 (ES3000PWR10WW) 24x10/100...
SMC EZ Switch SMC-8024L2 24-Port Gigabit Logo
4,091 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
