Question about Cradlepoint Inc WIRELESS N PORTABLE ROUTER802.11 B/G/N SPI NA - CTR35
Everything has worked fine since I bought it a couple weeks ago. This morning however it is as if the USB port that the air card is plugged into is dead. None of the l.e.d. lights on the air card light up when it is plugged in and the router doesn't recognize anything as being plugged in. I have two routers and two air cards and neither of the air cards work on the router in question but both of them do work on the other router which isolates the problem to the router itself. Any help would be appreciated.
M-Audio controller. How do I fix a loose sub port?
I just had the same issue. The temporary fix I used worked for 2 years. I just stuck a small paper clip or safety pin in the corner of the port, and then plug the cable in. If those are too big just use something you can use to make the plug fit tight.
It finally stopped worked a couple of weeks ago, so I just bought a new USB port at an electronic store for $1.50 and soldered it on. I had to buy flux which was $3.00.
$5 and an hour of time after squeezing 2 extra years with paper clips. Priceless.
Just make sure you have a cold beer to solder with. Sticking drinks in a freezer wrapped in a wetpaper towel for 15 minutes is like a reverse microwave for beer.
May 12, 2015 | M-Audio Music
MASS AIR FLOW SENSOR? 1991 Dodge Stealth RT
Yeah sound like the Mass Airflow sensor (MAF). This is one of those items you really shouldn't get at a junk yard.
Apr 21, 2010 | 1991 Dodge Stealth
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
Mar 15, 2010 | 1999 GMC Yukon
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
Problem with USB Flash
It is possible the memory stick is faulty. Are you using xp or vista? If so it should be recognised instantly. I bought one the same a couple of weeks ago, and it recognised it instantly, and I'm using xp.
Try it on another computer if possible, even where you purchased it. Just tell them you think it's faulty. If it works on that computer then you have a problem with either your usb ports or you have a virus.
Jan 01, 2008 | Electronics - Others
Printer doesn't work
The answer is probably down to the usb port, they don't always like change, because you are trying to swap hardware in same port, they tend to want to stay with one or the other peice of hardware. If you have'nt got another spare USB port, which i assume you have'nt, invest in a 2 or 4 port USB hub(But make sure it's powered by a AC power lead and not just a usb powered hub, because some hardware will not be recognised e.g I Pods), this connects into your usb port and gives you 2 or 4 port more to use, and you won't need drivers for it. They are inexpensive and you simply plug it in. I think this will solve it for you
Oct 23, 2006 | Samsung ML 2010 Laser Printer
Cradlepoint Inc WIRELESS N PORTABLE ROUTER802.11 B/G/N SPI NA - CTR35 Logo
90 people viewed this question
Top Cradlepoint Computers & Internet Experts
S. Pankratz
Level 1 Expert
Prashant M
Prashant M
Are you a Cradlepoint Computer and Internet Expert? Answer questions, earn points and help others
