Question about Refrigerators
My water dispensor leaks water after use and sometimes on its own
  • Refrigerators Master
  • 2,128 Answers
You have sediment in the water valve and the valve isn't closing all the way and water is leaking through the valve when it should be closed.you should send the model number so i can look up your machine and i could have given you the part number and price.call your parts store give them the full model number off of the machine,if it's a side by side open the fridge door,look up near the cieling and on the right wall and you should see the model number on the tag.pull out the fridge,pull off the bottom cover,unplug the machine,shut off the water supply to the fridge,take out the old valve and install the new one.
Posted on Apr 02, 2011
  • 3 more comments
  • charleswh24 Apr 03, 2011
    Model # FRS6R5ES84
  • Sal DeAngelo Apr 03, 2011
    the part number for the valve is 240531101 and it's around 60 dollars.FRS6R5ESB4,on the end of the model number that's a B as in boy not an 8,it's hard to see inside the fridge,you'll need the model number when ordering parts,i looked this up in the sears site,you can give your parts guy the model number again and tell him you need the water valve just to double check it and hopefully his price will be cheaper.good luck.
  • charleswh24 Apr 04, 2011
    Hey thanks alot although it seems to have gotten better, I've left a glass under it all day and there hasn't been any water, but if I do need to replace it is the valve in the backside of the unit on the outside> Note when I turn off my water to make connections then I turn back on I get tons of particulate corrorision from my old galv piping, I suspect thats the cause of my valve issue.
  • Sal DeAngelo Apr 04, 2011
    that's the problem sediment from the house pipes are getting into the valve,then when the valve tries to close it can't because of the junk from the pipes is stopping it from seating all the way.you can shut the house water supply down to the fridge,remove the water line from the fridge,put the line in a bucket and turn the water back on to flush the line,but if it happens again you'll know it's the valve,good luck with your machine,any more problems let me know,will be happy to help.
    Hey thanks a million I really appreciate your help
  • 6,784 Answers
HI.
The despenser is provided water, via inlet valve assembly. if there is a problem here, this will result in dripping, due to the valve not completely closing all the way after usage. Use the procedure to test and replace if needed.
Inlet assembly test:
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire please). You may need to use a pair of long-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not coming out of dispensor
two problem one water vale are the line were water come out is frozen the water splashes back and line freezes are water vale leakes
Jun 01, 2009 | Refrigerators
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Water dispensor not working
Did you use the correct filter?
Remove filter, and re-install. Make sure you have properly locked the filter into place as the locking mechanism assures the filter cut off valve opens.
Also, make sure any air was purged from the water circuit by holding the water valve open for a short period of time.
Jan 30, 2009 | GE Refrigerators
Coffee leaks after it is brewed
The water reservoir on this mdoel is very close to the coffee reservoir - if excess water gets between the wall of the coffeemaker and the coffee reservoir, it will leak exactly as you described. Make sure no water spills out of the water reservoir when your pour it.
-Tha Mp3 doctor
Nov 23, 2008 | Cuisinart DCC-2000
Water Dispensor leaking - HELP
shut off for the water supply igenrelly under the kitchen sink or in the basemant. no need to shut off main water supply to home. only to the unit itself
Oct 27, 2008 | KitchenAid KSCS25FKSS Side by Side...
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
